Old 12-04-2007, 08:41 PM   #1
90' Shelby pop-up headlights dont always pop-up ?
My Ride: 90' VNT,92'IROC RT
I have a 90' Shelby VNT that runs and drives great (90k miles).Problem now is that the head lights pop up some times and other times they dont ?They might work for 30 days and then they stop.
ANY HELP ?? !!
jdmr111 is offline
Old 12-04-2007, 11:30 PM   #2
Re: 90' Shelby pop-up headlights dont always pop-up ?
My Ride: 1990 Daytona ES
Engine: 3.0L V6
The headlight relay module needs rebuilt, the solder breaks down around the relays, on a 90 with the newer type interior (wrap around dashboard) its under the steering wheel, a black box about 3"x5" and is held on by a clip.
If its the older interior then its on top of the dashboard right around the middle.
Cut a line a few times around the seem of the box, then it should pop off, next the board has some hardened material above the board, just chip away slowly at it trying not to hit the ciruit board, if your lucky it will come apart in a couple of chunks. from there then you will see the bad connections on the relays that need rebuilt.
Pulling one from a junkyard might also have the same problem, especially if the headlights are in the up position.
roguetrip is offline
Old 12-05-2007, 08:47 PM   #3
My Ride: 92 Iroc R/T Red
Engine: TIII
Headlight Module Repair Part 1(Illustrated)
Headlight Module Repair Part 2(Illustrated)
I think this is for the older style module but you will get the idea
Tim
charger R/T is offline
Old 12-05-2007, 10:15 PM   #4
My Ride: 87 Daytona Shelby Z
Engine: 2.2 turbo
I did this repair a few weeks back on my '87 Shelby Z and it worked great.
One other thing to look for is the Headlight screw adjusters. They are made of plastic and crack over time. This leave the headlamp floping around and can jam in a positon not allowing the motors to open. There is a manual emergency knob that lifts the lights up, it is covered with a rubber sleeve to protect it from moisure. It can bee seen when the hood is open. Check you owners manual for location and how to operate in emergency.
ntxdodge is offline
Unsecured Credit Cards | Remortgages | Loans | Loans | Mortgage Calculator
Page generated in 0.31809 seconds with 13 queries
