Old 12-12-2007, 08:15 AM   #1
Tach in a non-tach vehicle
Let's say I want to put an instrument cluster that has a tach in a car that came without a tach (vehicle in point is a 92 caravan). Do the dash/engine harness come with the tach signal wires, so once you put the right cluster and provide a tach signal it will work? Or, you have to run the wire yourself (i.e. there are different harnesses)?
dalek is offline
Old 12-12-2007, 11:49 AM   #2
Re: Tach in a non-tach vehicle
Old School Hot Rodder
85lebaront2's Avatar
My Ride: 1985 LeBaron Vert
Engine: MOPAR 2.2L
92 Caravan, the instruments are run by the BCM. I believe (may be wrong) the only difference in the BCMs is analog vs. digital instruments. At worst case, you may need a BCM from a 92-93 with tach. I may have some parts soon, I am acquiring a 93 parts van from a friend.
Bill Vose
1986 Turismo 2.2 (race car)
1986 LeBaron convertible 2.2L TBI (dead)
1986 F350 Crew Cab DRW
1993 Grand Caravan 3.3L
85lebaront2 is offline
Old 12-12-2007, 02:29 PM   #3
My Ride: TIII R/T
Engine: 2.2L TURBO III
Feedback: (9)
if if has no tach as long as the car has a distributor you can run the tach singal off the coil
xtrempickup is offline
Old 12-12-2007, 04:33 PM   #4
Yeah, that is what I meant by having to run the wire yourself. I was just thinking: if the harness can handle it, I might as well use it, right?
dalek is offline
Old 12-12-2007, 07:44 PM   #5
My Ride: 92 Iroc R/T Red
Engine: TIII
I agree with 85lebaront2 that the BCM drives the dash and it should work by just by swapping the dash. I would guess you don't have a digital dash since you don't have a tach. I think all digital dashes in that year van would have the tach. I have a junk 92 mini van I will somewhere down the road strip. It was loaded with full gauges.
Tim
charger R/T is offline
Old 12-14-2007, 07:12 AM   #6
Smoking Rice in a Minivan
86LaserXE-XT's Avatar
My Ride: 89Turbo Caravan
Engine: 2.5 Turbo 1
I'm not sure about a 92 caravan but on the older models you can just plug the tach dash right in and it will work, only thing you need to swap is the temperature sensor
as your old dash has a tempature switch for the idiot light instead of a sender for the gauge that the tach dash has.
good luck. Let us all know how it turns out.
86LaserXE-XT is offline
Old 12-14-2007, 11:45 PM   #7
My Ride: 89 omni & 90 T1 shad
Engine: 2.5L HX-35 w/alcohol
as far as i know, all harnesses are wired for all gauges, but the dashes were just difforent. some had tachs, some didnt. i think you can just get a dash with a tach and it should plug in to a plug in the dash just waiting for a tach. ??
turbo minivan is offline
Old 12-14-2007, 11:47 PM   #8
My Ride: 2 messed up dodges
Engine: 10:1 3.0 5 speed
Images: 1
I agree with turbo_minivan. I've put tach clusters in 3 vehicles that didn't have them from the factory and it was plug and play. I spend the extra time to swap the original odometers in to keep the mileage accurate.
jory is offline
Old 12-15-2007, 02:39 AM   #9
My Ride: '88 Daytona w/t-tops
Engine: 1.65 TII-3 Cyl-lol
Yeah, it also works that way on newer dodges as well. We had a first gen neon and just swapping in gauges worked.
kermit is offline
New York Hotels | News | Loans | Credit Card | Tienda de libro
Page generated in 0.33015 seconds with 13 queries
