Old 01-27-2008, 02:07 PM   #16
Re: APEXi stuff
My Ride: 91 shelby daytona
Ok i get the wideband and afc thing, so basiclly a good setup would be the wideband, 3bar map with something like the d-cal? I Need to do a bit more research on the 3 bar. To use that do you HAVE to have your comp. flashed to be able to use it? (sounds like you do) Guess i'm just not sure if it needs to be recognized or if it works on it's own. I've heard people having tuning issues with the 3-bar map too, i'm guessing that it's just for finicky?
I apologize if it sounds like i don't read into it enough myself first but you have to admit the answers usually are more direct here. that and it takes 10 minutes to load up any other page with this gay dial-up...i do live in VT remeber.
Powell is offline
Old 01-27-2008, 02:19 PM   #17
Re: APEXi stuff
My Ride: '87 Daytona Shelby Z
Engine: 2.2l TII
Feedback: (6)
Images: 3
Originally Posted by Screamin4banger View Post
A wideband O2 is a 5volt (instead of 1volt) sensor that some ECUs can take advantage of, but mostly is a pretty gauge to screw into your dash.
Just a pretty gauge?? I would love to see you try to tune a high boost car, or any car really, reliably with a narrowband. Wideband is probably the most important tuning tool
impuresoul2k3 is offline
Old 02-06-2008, 12:51 AM   #18
Re: APEXi stuff
Politically Incorrect
Screamin4banger's Avatar
My Ride: 85SC/86SC/91RT/73SE
Engine: 2.2/2.2/2.2/6.6
...YEP.
If you would read the thread before jumping on me, you should get my point. I never said that a WBO2 was not an important tuning tool - This thread's not about whether it is or isn't.
The fact remains that simply installing a WBO2 in your vehicle will give you no more control over the computer than you had before.
Screamin4banger is offline
Loans | Loans | Loans | Loans | Credit Card Consolidation
Page generated in 0.43007 seconds with 13 queries
