12-28-2007, 10:15 PM
Re: blower switch
That is very common that the blower switch is not replaceable on Mopar control units.
Most Mopar blower switch's control ground,power is constant to the blower resistor and bypass's the resistor for "High".If this is the case you should be able to put a toggle switch on the ground side and get 1 blower speed to work until you can get the correct part.
Be sure your connector did not melt,if it did grab the pigtail at the yard when you go.
