12-30-2007, 05:42 PM
90 Spirit Speed Sensor Problem?
My Ride: Jaguar
Speedometer not working and it has Code 15. I am trying to rule out bad connection, etc. before buying the $42 part.
I had my assistant spin the shaft in a drill chuck while I held multimeter probes on the pins.
I tried both ways +/- in both spinning directions.
Had the meter set on its lowest voltage setting -- 2 volts and got nothing at any time.
Did I check it correctly or is there another test?
Thank you
