Old 01-27-2008, 05:24 PM   #1
Question 91 Turbo Daytona Cluster
My Ride: Dodge Ram 1500
Engine: Hemi
My gages are not all working, the boost isnt is there a way to check them are not. The tack and alt. are working but the temp. isn't. Would I be better off finding a different cluster. THANKS RONNIE rfralicks@yahoo.com
okie mopar is offline
Old 01-27-2008, 06:11 PM   #2
Re: 91 Turbo Daytona Cluster
My Ride: TIII R/T
Engine: 2.2L TURBO III
Feedback: (10)
temp is related to a sensor, check the codes in the computer see what it says first. boost is related to a hose from under the hood to the cluster.
xtrempickup is offline
Old 01-27-2008, 08:56 PM   #3
My Ride: 92 Iroc R/T Red
Engine: TIII
temp gauge sensor is a differant sensor then the computer uses for temp so no code would set if its bad. You didn't say what engine you have. V-6 has the 1 wire sensor next to the thermostat housing. I would also guess an 8 valve 4 cylinder should as well. I know the TIII is near the thermostat as well. look for a small sensor with a 1 wire push on plug. the sensor has a stud for the wire end to push on. If you ground the wire with the key on the gauge should go all the way up if the wiring and gauge are good.
Tim
charger R/T is offline
Old 01-27-2008, 09:33 PM   #4
Engine: Hemi
It is the 4cyl. turbo. Will the vaccum line be a small hard one? THANKS RONNIE
Old 01-27-2008, 09:43 PM   #5
Engine: TIII
The vacuum line probably is a hard line.
Tim
Old 02-10-2008, 10:34 AM   #6
My Ride: 92 IrocR/T 90 Shelby
Engine: 2.2 TIII, 2.5 TI
look for the vacuum line to be broken or split back by the map sensor... that is where i have had two that were broken.
Bkwales is offline
Old 02-10-2008, 11:10 AM   #7
Question Re: 91 Turbo Daytona Cluster
Engine: Hemi
Where is the map sensor located at? I don't even know where to look. The gauge is setting at about 3lbs minus so is it broke are just hung there? Yhanks for the info. Ronnie
Old 02-10-2008, 11:32 AM   #8
My Ride: 1992 Dodge Daytona
Engine: 2.5l I-4 super 60
Sorry, I am having a difficult time understanding your grammar.
That vacuum line that goes to the boost guage goes through the firewall on the passenger side of the car, which is also where the MAP sensor is mounted. Someone undoubtedly was messing around with vacuum hoses under the hood and didn't hook everything up correctly, so now the boost guage no longer functions.
phantomrt is offline
Old 02-10-2008, 12:42 PM   #9
Engine: Hemi
Is the map sensor located on the firewall are on the motor? Thanks Ronnie
Old 02-10-2008, 04:37 PM   #10
To check your temp gauge locate the Temperature Sending Unit (in the block above the oil filter, single wire) and with the key on/engine off ground the sending unit wire, if the gauge moves to full hot the sending unit is your problem, if not the problem is in the wireing or cluster.
The vacuum line for the boost gauge runs across the top of the P/S Pump pulley and into the vehicle thru the firewall on the passenger side.If the line is not damaged under the hood you will need to remove the cluster and be sure the line is connected and there is vacuum there.
The Map Sensor is located behind the P/S Pump on the firewall.
NAJ is online now
Free Advertising | Loans | Libro infantiles | Unsecured Loans | Car Insurance
Page generated in 0.36482 seconds with 13 queries
