Old 01-28-2008, 07:53 AM   #1
Question 91 Daytona power ant.
My Ride: Dodge Ram 1500
Engine: Hemi
My ant. doesn't raise up when you turn the radio on. Are they bad about breaking? Is it on a fuse by its self? I didn't get a owners manuel with the car. THANKS RONNIE rfralicks@yahoo.com
okie mopar is offline
Old 01-28-2008, 09:06 PM   #2
Re: 91 Daytona power ant.
My Ride: 92 Iroc R/T Red
Engine: TIII
Here check out this thread post 12 has a diagram with the power antenna in it. HELP!! infinity speaker problem
It probably is a diagram for 90 so it should be close. The whole thread may end up helping.
Tim
charger R/T is offline
Old 02-20-2008, 10:16 AM   #3
My Ride: 92 Chrysler Imperial
Engine: 3.8l V6
The tape that drives the mast up and down likes to break over time. The solution is to disassemble the antenna to pull out the broken pieces and replace the mast. You should be able to locate a new mast at the dealer, or there may be some up on eBay. I have two power antennas myself needing that operation
If you can't hear the antenna motor running, the fault could be due to the relay not turning on (if the car has Infinity you will also get no bass as the woofer amps run off the same relay), or the power antenna motor itself going on the fritz. One of my power antennas is a little flaky - it won't run sometimes until you smack the fender nearby.
Oklahoma Wolf is offline
Website Design | Loans | Credit Cards | Problem Mortgage | Mortgages
Page generated in 0.29294 seconds with 13 queries
