04-01-2008, 04:32 PM
Re: coolant temp sensor
My Ride: 1988 LeBaron 'vert
Engine: 2.2L I-4
There are 2 coolant temp sensors. The one that you unplugged at the water outlet is the one for the fan. The other is on the front of the block to the right of the AC/alt bracket. It has one wire going to it. From the sound of your problem, the issue is probably in the cluster because both your volt gauge and temp gauge don't work.
