04-12-2008, 08:22 AM
Re: getting code 11 and car has power ?
If you turn the key and have no crank start with basics, is the battery fully charged and able to hold a load, are the cables tight and free of corrosion, is there power to the starter, should be constant 12 volts from Batt+ and 12 volts on the solenoid terminal with the key in the start position. If no power at the solenoid terminal check the starter relay,2 power feeds, 1 constant, 1 from ignition switch with the key in the start position, 1 output to starter and a ground which is thru the neutral switch on an auto trans.
By the way, what are we working on?
