Old 04-30-2008, 06:31 AM   #1
86 glht fuel pump setup ? and o2 question
Junkyard Booster
My Ride: 86 GLHT
Engine: 2.2 turbo
what the hell is the deal with the external pump and the in tank pump? is the external like a booster pump? or does it stay on all the time? how much boost is safe with it? running a t2 setup. also i have this 2.5in swing valve installed on my omni and it has a 3 wire o2 in it. i still have the 1 wire setup in the car. i was wondering if i can just put the single wire from my car to one of the wires on the o2? or do i have to make a power and a ground then add the wire. btw im running a s60 computer aka the 86 glhs stage 2 mopar unit.
roachjuice is offline
Old 04-30-2008, 07:37 AM   #2
Re: 86 glht fuel pump setup ? and o2 question
My Ride: 85ShChgr, 91SprtR/T
1) the pumps: one was a lift pump and the other a pressure pump. The modern thing to do is replace that setup with a single pump capable of supporting your build.
2) O2: yeah you *could* use it without the heater circuit - But you might as well wire the heater circuit up - Then you know for sure it's ready to go when the computer looks for a reading.
3) S60: ??? The S60 didn't use an O2 at all. I guess I'm not sure about the GHLS Stage II... I thought it did.
Screamin4banger is online now
Old 05-01-2008, 12:09 AM   #3
My Ride: 86 SC, 94 Duster
Engine: 2.2 TI, 3.0L
GLHS stage II & S60 computers are 2 totally different computers. The GLHS is a logic module & the S60 is a SMEC. The S60 doesn't use an O2 & is 3-bar/+40% injectors.
sittn86 is online now
Old 05-01-2008, 04:30 AM   #4
Junkyard Booster
My Ride: 86 GLHT
Engine: 2.2 turbo
how to i wire that bastard up? thanks for the replies. and what is the glhs stage 2 calibrated for? stock setup?
Old 05-01-2008, 06:20 AM   #5
One wire of the O2 (I think black) goes to the computer, the other two go to ignition & ground. If you're asking how to wire up a single pump, just hook the red one up to + & the black one to -. I don't think that's what you're asking, though. The hardest part about doing the pump is that high-flow pumps like the Walbro don't fit in the hanger too well. It's much easier if you can acquire an '88-'90 hanger assy. That's what I did, thanks to 4DRVNT. He really saved me a bundle.$21 as opposed to $140. It was brand new, too. The GLHS stage 2 is basically stock, aside from what I wrote in post #3.
Old 05-01-2008, 06:27 AM   #6
Oops, double post.
Debt Help | Mobile Phone | Loans | eHarmony Promotional Code | Car Insurance
Page generated in 0.30401 seconds with 13 queries
