Old 05-17-2008, 05:13 PM   #1
Blown fusible link
Turbo224's Avatar
My Ride: Daytona R/t
Engine: Turbo III
Images: 224
So here is the deal. I just did the T2 swap in my 86 Omni and converted it over to 87 electronics. I got eveything hooked up and the car starts just fine. The only problem I noticed is the first time I hooked the battery up sparks shot out from the terminal and I saw smoke coming from somehwere behind the battery but then it went away. I couldnt find where it came from so I started the car and didn't think about it. Car runs and drives great, alt gauge says its charging, however the battery is not getting charged. Turns out I melted the red fusible link for the alternator when I hooked the battery back up so the car was running fine, but only off battery power. When the car is started and I unhook the terminals it dies immediatly. So I fix the fusible link and go to hook up the battery again and the terminals do the exact same thing, they spark like mad. So I pull them off quickly before I melted the fusible link again but now I am stumped.
I have checked and rechecked all the grounds on the car and they are good (FWD ground wire kit installed) I am running a newer ND alternator, so I added and extra ground wire to the alt because the newer ND's have two grounding posts unlike the old alternators. I am fairly possitive that I have the correct power line to the alternator on the correct post. I was running this ND alternator before I did the T2 swap and it was charging just fine before. So what should I be looking for here?
~Tyler~Salt Lake City~Proud SDAC Memeber~
-92 Daytona R/T (PVP Pilot Car)
-92 Daytona R/T
-87 GLHS #907
-86 Omni GLH-T
-70 Plymouth Cuda 440-6pk (in progress...sort of)
Check out my Homepage
"Half the people you know are below average"
Turbo224 is offline
Old 05-17-2008, 06:54 PM   #2
Re: Blown fusible link
My Ride: OMNI/ShelDak/TSi/SL
Engine: 2.2 'GLHS style' TII
Feedback: (36)
on my omni the radiator was slid all the way over and was hitting the alternator field wire terminal posts
a quick check would be to disconnect the alternator sub harness and see if you still have the short ..
detobias is online now
Old 05-18-2008, 12:49 AM   #3
Figured this may help.
Here is the charging system wiring for an 87 T-2.
NAJ is online now
Old 05-18-2008, 02:19 AM   #4
Turbo224's Avatar
Engine: Turbo III
Images: 224
Yeah, the alternator was sparking off the radiator, I forgot to mention that, but I added the plastic piece that prtects the post which I have previously removed and the sparking hasnt happened again since then.
Also for got to mention that I have tried swapping the pm and no change.
-92 Daytona R/T
-87 GLHS #907
-86 Omni GLH-T
Turbo224 is offline
Buy Anything On eBay | Teen Chat | Internet Advertising | Mortgage Calculator | Credit Cards
Page generated in 0.34077 seconds with 13 queries
