Old 05-29-2008, 05:42 PM   #1
where should I an wire electric waterpump for A/W IC
My Ride: CSXT
I have an electric waterpump from a ford lightning that I am going to use for my A/W IC setup. I am just unsure of where I should Wire it up or how? I was thinking I might hook it up directly to the battery and running a switch to my cabin so I could turn it on when I was going to get on it, and so it was not running all the time. But there is that nagging feeling in my head that I would forget to turn it on or turn it off... So if I was going to wire it up so it turned on with my car where would I get the power from?
Edit/Delete Message
juxsa is offline
Old 05-29-2008, 05:56 PM   #2
Re: where should I an wire electric waterpump for A/W IC
Authorized TD Vendor
JamesL's Avatar
Edit/Delete Message
I forget the exact fuse location but a quick check with a test light will help you find key on power. Depending on the number of amps the pump draws you might want to wire in a relay.
FWD Performance is happy to provide tech support for products purchased from any vendor. If you can't get product shipped on time or get qualified tech support from your current vendor it's time to do business with FWD Performance. Real Race Products by Real Racers.
FWD Performance, making the genuine investment to bring you a variety of quality products in one stop delivered to your door FAST
JamesL is offline
Old 05-29-2008, 06:09 PM   #3
My Ride: 92 Shadow
Engine: 2.5 T1
I would definately use a relay.
Though I would find a way to make it run only when the engine is running. Maybe wire it to run with the fuel pump?
bhazard is offline
Old 05-29-2008, 06:14 PM   #4
My Ride: CSXT
so look in the fusebox for the key on fus and wire a relay up to that and the wire the pump from the battery to the relay?
juxsa is offline
Old 05-29-2008, 06:32 PM   #5
JamesL's Avatar
Pump - to ground, pump + to relay + output(87). Relay constant to Battery (30). Relay ( (86) to switched power (or run only power). I prefer negative ground switch so relay pole (85) to switch terminal 1 and switch terminal 2 to ground. flipping the switch activates the relay which sends battery power to the pump. I'd put the relay with the rest of the existing relays by the battery. You've got everything you need power and ground wise there.
JamesL is offline
Old 05-29-2008, 06:55 PM   #6
My Ride: CSXT
ok... so Pump - goes to ground
Pump + goes to relay would that be #87 on the relay?
Relay #30 to + battery or + alternator
Relay #86 to switch or what ever fuse turns on in the fuse box when I turn the key on. Maybe the radio?
Hows that sound?
juxsa is offline
Old 05-29-2008, 07:07 PM   #7
JamesL's Avatar
yes, the negative wire on the pump can go to the block
yes, 87 is the output terminal on the relay
Yes
If you want to switch power then yes, put a switch between the 86 terminal on the relay and the switched power source from the fuse box or steering column and depending on how your radio is hooked up, that might be true also. Then attach relay terminal 85 to ground. I prefer to switch GND. If you switch GND and place the relay near the rest of the relays under the hood, you will only need to run one wire back into the car from the relay to the switch. Draw yourself a diagram before you start.
JamesL is offline
Old 05-29-2008, 07:55 PM   #8
Resident piston cracker
crazymadbastard's Avatar
My Ride: 92gtc vert
Engine: 2.5 8v
Feedback: (21)
umm sorry did not read your post properly.
I would do a boost referenced switch going to a relay. say once you go above say 5psi it kicks on. Do it at a low psi so it does not heatsoak the ic.
dyno sheet
I practice what I preach:
1992 GTC convertible 2.5/568 aluminum fw/Tu 6puck feramic/s60/3in Tu sv/+40S/ FWD CAL /FMIC/self ported head+1mm exh valves/self ported ex mani/stock 2piece w/stock tb/PSSSSTSSSS
crazymadbastard is offline
Old 05-29-2008, 08:42 PM   #9
My Ride: CSXT
it would be super rad to put some kind of thermostat so that it kicks in when the water temps gets above a certain temp but I don't care that much. Does any one know if the ford lightnings water pump was temp controlled or was it always running?
I will have to take a look next week behind the fuse box to see how if I can just splice a wire from there to the relay
juxsa is offline
Old 05-29-2008, 09:20 PM   #10
My Ride: 89 Omni
Engine: 2.5 Turbo
Feedback: (6)
Summit and Jegs sell a kit to do exactly that and one that is adjustable for I think around 50 - has the sensors - relays and etc with it.
clarkwhoracing is offline
Old 05-29-2008, 11:55 PM   #11
My Ride: CSXT
you know what the kits might be called? I will take a look for it if I new what to look for. Those stores have so much stuff its hard to find things unless you know what it is.
juxsa is offline
Old 05-30-2008, 07:36 AM   #12
My Ride: 89 Omni
Engine: 2.5 Turbo
Feedback: (6)
Here is what I was talking about
Flex-a-lite 31147 - Flex-a-lite Adjustable Temp Control Switch - JEGS
fan control - JEGS High Performance
There are a bunch of other stuff similar that might work and are adjustable.
I am going to convert my omni to an electric pump but straight running all the time when power is to the key.
Hope this helps.
Old 05-30-2008, 10:45 AM   #13
JamesL's Avatar
Hope this helps.
I think he is talking about running a water pump? You could thermostaticly control it. I'm not sure I've ever seen that or what the benefit would be other then not having to turn a switch on. I guess the car would warm up quicker.
JamesL is offline
Old 05-30-2008, 12:59 PM   #14
My Ride: CSXT
Thanks for the input but I was talking about having the pump shut on or off. I don't think I am going to run a fan on the IC Radiator unless I really need to. And when I am at the track I was thinking about putting dry ice in my reservoir to get the temps down super cool
Hope this helps.
juxsa is offline
Old 05-30-2008, 01:14 PM   #15
JamesL's Avatar
My bad, I didn't realize this pump was for an A/W IC. Dugh...its in the subject liine.
JamesL is offline
» Market Place
