Old 06-17-2008, 07:44 AM   #1
Dead Heater / Fan Blower Motor - 86S
Checked fuse and it's good. Can anyone tell me where to start with this one?
If I end up replacing the motor, will I have to pull the dash?
I found an '85 Omni service manual and it said to check the fuse and then to check power to fuse ends? I'm guessing this means to check for power to the fuse box in slot 4/5(?). All other electrical seems to work fine.
I'm not planning on driving the car in the winter and AC isn't really necessary in Michigan but I'd like to get it running.
Thanks
cqlink is offline
Old 06-17-2008, 02:02 PM   #2
Re: Dead Heater / Fan Blower Motor - 86S
My Ride: 87 GLHS
Engine: 89 CB 2.2
Thanks
On my older MOPARs there is a resistor block mounted in the heater box that gives you the different speeds. Should be the same for our TD's (I'll look in my FSM when I get home). They're just exposed coiled resistor wires (kinda like a toaster) sitting on the inside the box. These sometimes break. Put a ohm meter on the treminals (sticking out of the side of the heater box) and you should get a reading (not sure what amount) if not they are broken inside. Easy fix if thats the cause.....
Steve St"RACE"ner
It's been fun but I'm outta here!
powermaxx is offline
Old 06-17-2008, 06:55 PM   #3
Read a little about the swtich, motor, resistor and tried running it again while crusing around 60mph on high speed.
It didn't blow really hard but it seemed to work.
The fan actually ran a little stronger at the medium low position.
Bad switch, short?
cqlink is offline
Old 06-18-2008, 07:50 AM   #4
My Ride: 86 SC, 94 Duster
Engine: 2.2 TI, 3.0L
Probably the switch... It's pretty common in L-Bodies. Take it out & check for continuity. Be very careful not to break the plastic body of the control assembly. It's not that big of a deal, but that 22 yr old plastic is brittle.
Sittn86 is offline
Old 06-18-2008, 09:31 AM   #5
Do you know where it is? I still don't have a manual (hoping to correct that this weekend at SDAC). Thanks
cqlink is offline
Old 06-18-2008, 10:56 AM   #6
The switch? It's in the dash. You know, the thing you move to change the fan speed? Search ebay for 86 chrysler manual. They appear from time to time. It's a 3 volume set. I paid around $32 for the set in nearly new condition, so try not to get screwed.
Sittn86 is offline
Old 06-18-2008, 01:22 PM   #7
My Ride: 1992 Daytona R/T
Engine: 2.2 TIII
If it works on all the speeds, its more than likely the resistor, not the switch. Look down into the intake in the cowl area for the resistor. It will look like a few sets of heating elements.
gkcooper is offline
Old 06-18-2008, 01:23 PM   #8
Thanks...Not sure what type of switch I should be going after. Didn't think it would be an easy one.
cqlink is offline
Best Credit Cards | Mortgages | Best Credit Cards | Loans | Honda CBR600RR
Page generated in 0.40384 seconds with 13 queries
