07-06-2008, 11:53 PM
Re: lights problem
Yes, Hazards = 4 Ways, we have had TDers with turn signals not working because the Hazards were on so check the obvious first.
If that is not the case start by testing ALL fuses, a blown fuse for another circuit will create a stray voltage looking for ground and if it finds it thru the stoplamps they will stay illuminated whenever a ground is supplied such as when the lights are turned on.
After that I would be at the stoplamp switch, the switch should be open(no current output) until the brake pedal is depressed. It is also common for wires to break at the stoplamp switch connector. Be aware that if you have cruise half of the switch is stop lamps and the other half is for the cruise to let the PCM know you have stepped on the brake and it will disengage the cruise.
