07-14-2008, 08:46 PM
Re: 1983 d150 alternator help
My Ride: 92 Iroc R/T Red
Engine: TIII
with that battery wire fried the regulator will full field the alternator and since it has no where to go the voltage will be high. I have seen 30-40 volts before when it fries the fuse link. The 60 volts makes me wonder if it has a standard chrysler alternator or the old school chrysler 100 amp alternator. They did sometimes have them but very rare. If it does have a 100 amp alternator it would be a very big alternator and it is rubber bushed mount. Check the ground wire to engine. It could cause the same reading if the ground is open and the volt meters negitive lead is hooked to either body or engine. If it doesn't have a hugh alternator with rubber bushings it is solid mounted chrysler unit.(no ground wire needed or used by factory) As far as someone swapping in the bigger 100 amp I would doubt it since the mounting brackets are differant and hard to find.
Jan looking it up either 6 or 8 and feedback or not shouldn't matter. The circuit should be the same. Just differant wire size for B+ for a 100 amp if it was an option. Plus a ground strap for the 100 amp option.
Tim
