07-31-2008, 10:49 PM
Re: Fuel Pump issue 92 R/T
Your test light was connected to ground and you were losing power. Be sure you are actually getting 12 volts back to the pump, excessive resistance in the wiring will drop the voltage. Check for 12 volts while cranking, if there is no power check for power output out of the ASD relay, if there is power but not 12 volts test voltage at the ASD relay.
Your vehicle also uses a fuel pump relay in conjunction with the ASD relay. Power is from the ASD to the fuel pump relay to the pump. If power is good at the ASD check power output at the fuel pump relay, if ok test the wiring
The ground is located in the R/S Quarter Panel, it runs thru a connector also in the R/S quarter panel before the actual ground location.
