Old 08-10-2008, 02:51 PM   #1
Code 44 ???
Hi Guys
My 85 GLHT has a CODE 44 showing ... any ideas on what this is ?
Or what it needs to fix it ?
Thanks Earle
mr_niteowl is offline
Old 08-11-2008, 04:29 PM   #2
Re: Code 44 ???
My Ride: 1991 Dodge Daytona
44 No FJ2 voltage present at logic board
44 Logic module self-diagnostics indicate problem
44 Battery temperature out of range (see Note #1!)
Note #1: The power module has an air-cooled resistor which senses incoming air temperature. The logic modules uses this information to control the field current in the alternator. This code applies ONLY to alternators whose voltage is computer regulated. If you lose the feed to keep RAM information stored when the engine's off, you also lose battery voltage sensing. -- Bohdan Bodnar
source: 1980s Chrysler, Plymouth, and Dodge computer fault codes
daytonav691 is offline
Books | Free Credit Report | Hosting | Mortgages | Phpnuke Database
Page generated in 0.27655 seconds with 13 queries
