08-19-2008, 09:48 PM
Re: Need RKE Wiring Diagram (dealer installed)
My Ride: 88 omni, 84 rampage
Connect the dark green program wire to ground. Then the door locks will cycle to indicate the receiver is ready. Press any button on transmitter to set code. If there is a second transmitter, program it at this time. The door locks will cycle to confirm programming has taken place. Disconnect the dark green program wire. Hopefully that will help you.
