Ok so i bought an 88 daytona shelby z, and it has some issues that i'm working out.
The biggest of them is this:
The passenger side window blows the Power window fuse when you try to roll it down. It wont blow the fuse when you try to roll the window up, or roll the driver side window up or down.
Trouble shooting done so far:
-Unplugged the window motor, Still blows the fuse when you try to roll the passenger side window down.
-removed the window switch, and used jumper wires to roll the passenger side window down: Window rolls down with out blowing the 25 amp fuse.
-So i replaced the switch with a used switch, STILL blows the fuse.
-Checked for a short to ground on both the purple and the green wire with the test light hooked up to power test light will not light, no short there.
The only thing i can think of is maybe the 2 wires are shorted togeather in the door jam, but then it should blow the fuse in either the up or down position.... Any ideas?
