09-04-2008, 07:14 PM
Re: Infinity CD swap
My Ride: 92 Chrysler Imperial
Engine: 3.8l V6
As you discovered, it's plug and play. Infinity and non Infinity decks are usually no different from each other in the amp sections, though the non Infinity models usually are missing the 8 pin slave CD connector. There are certain common ground 1984 radio models you should not use with the Infinity speakers, and some tuner only ones that won't work, but apart from that you can plug almost anything into the dash made between '84 and '00 and it will work with the Infinity speakers.
It's because the Infinity systems are usually bi-amped... they still need the amp in the radio to drive the tweeters.
