01-12-2009, 01:27 PM
#24
Re: Adding AUX port to '91 Infinity head unit
My Ride: 92 Chrysler Imperial
Engine: 3.8l V6
The Infinity III is incompatible with all CD changers that rely on a direct connection to the deck - the port on the back was designed only for the single disc slave CD player, and contains no data bus or control circuitry for the changer. You need one of the two decks with the mode button to connect the changer to, like this one:
And it has to be the older Chrysler 6 disc changer to work as well. You can also get an interface from PIE to hook up certain Alpine M-Bus 6 disc changers.
Here you go:
These are found in the dash of 1988-1989 minivans and the rear of 1988-1989 LeBaron Convertibles only. To use them properly, you need to power the amps on them to keep the EMITs from being drowned out by the woofers. Requires running 12V to the amps and a speaker level input signal. Pinouts on them are red-amp 12V in, gray-amp ground, black-positive audio, green-negative audio.
