Old 10-05-2009, 07:54 AM   #1
Blower motor?
TD Hardcore User!
My Ride: 92 sundance duster
Engine: 3.0L 24v
my HVAC fan only seems to work on med high and high, and i already have replaced the HVAC controls to get the selectors to work. am i looking at a power supply problem or a blower motor problem?
Shadow24V is offline
Old 10-05-2009, 09:00 AM   #2
Re: Blower motor?
Level 1 Supporter
My Ride: OMNI/ShelDak/SL/XR7
Engine: 2.2 'GLHS style' TII
Feedback: (58)
I'm not familiar with the modern '90+ TD's ;) BUT yur prolly in luck
cheap MaMopar has a simple 1-speed fan, and uses a bank of heavy duty resistors to waste amperage whn yu ask for medium or low speeds
these resistors burn out one by one, so yu lose one speed at a time
on my ShelDak its mounted pass side firewall, by A/C passthru ; ~6 wire connector
resistor bank pops out with 2 screws
detobias is offline
Old 10-05-2009, 09:14 AM   #3
Re: Blower motor?
TD Hardcore User!
Engine: 3.0L 24v
hmmm, ill take a look, thanks
Old 10-05-2009, 06:30 PM   #4
Re: Blower motor?
TD Hardcore User!
My Ride: 92 Iroc R/T Red
Engine: TIII
the resister is always in the air stream of the blower motor so it can cool it. so it is near the blower but with the way they do the heater box some cars it is inside and others are under the hood. daytona it is inside above the blower mini van it is under the hood dakotas under the hood.
Tim
charger R/T is offline
Old 10-05-2009, 07:16 PM   #5
Re: Blower motor?
TD Hardcore User!
Engine: 3.0L 24v
ok, i didn't see anything under the hood, so i'll go digging into the blower box to see if i can find them. anyone have a clue as to what sort of resister i'd need? resistance and wattage?
Old 10-05-2009, 07:32 PM   #6
Re: Blower motor?
NAJ's Avatar
Feedback: (7)
Your resistor is under the cowl behind the washer bottle.
AutoZone.com | Vehicle Selection | Year
NAJ is online now
Old 10-05-2009, 07:36 PM   #7
Re: Blower motor?
TD Hardcore User!
Engine: 3.0L 24v
oh, cool, thats easy. guess its pull it and read the bands for a replacement?
Old 10-05-2009, 07:43 PM   #8
Re: Blower motor?
NAJ's Avatar
Feedback: (7)
Blower motor resistors are common on all vehicles for failure.
The control unit controls the ground side of the resistor and power is constant at the resistor.
The control head changes which terminal the current will flow when you change speeds by connecting/disconnecting a ground.
For low speed the current flows thru all of the resistors which lowers current flow thus giving you low speed.
High speed bypasses all resistors and is staright from the resistor input to the blower motor.
The blower resistor is not servicable and replaced as a complete unit.
NAJ is online now
Old 10-05-2009, 07:47 PM   #9
Re: Blower motor?
TD Hardcore User!
Engine: 3.0L 24v
crap, they don't make it easy do they lol. best bet is a j-yard unit im guessing? probably NS1 at the dealer anyways...
Old 10-05-2009, 07:49 PM   #10
Re: Blower motor?
NAJ's Avatar
Feedback: (7)
No, No, No.
That is why I sent you the Autozone link, it's like $12.00.
NAJ is online now
Old 10-05-2009, 08:43 PM   #11
Re: Blower motor?
TD Hardcore User!
Engine: 3.0L 24v
woops, missed that lol. thanks
Old 10-05-2009, 09:11 PM   #12
Re: Blower motor?
TD Hardcore User!
Engine: TIII
check dealer prices I bought one for a 94 dakota a year or so ago from chrysler for about 5-7 dollars. advance auto wanted 20.
Tim
Old 10-06-2009, 01:21 AM   #13
Re: Blower motor?
Level 2 Supporter
crusty shadow's Avatar
My Ride: 88J 94P 03dime
Engine: 2.2 in all of em
i had a similar problem on mine- i pulled out the resistor bank and could see all the solder joints were bad- reflowed them with fresh solder and it worked perfectly again.
crusty shadow is offline
Page generated in 0.20255 seconds with 11 queries
