10-08-2009, 05:59 AM
can't get my fan to work
Level 1 Supporter
My Ride: 92 Daytona Shelby
Engine: 2.5CB TI/TII
Hi folks,
FINALLY my 92 T1 Tona is back on the road :) there's just one problem, the radiator fan won't come on. at first i suspected my hacked up wiring because the fan (it's a TII rad/ ic fan) didn't have a connector, i got it with just 2 wire stubs sticking out so i had to wire it up to the existing fan connector in the engine harness. anyways, i tried the fan directly fed by battery and it worked, so the fan motor is not dead. next thing i did was trigger the fan ON by unplugging the CTS with the engine running but nothing except a short bump in idle rpm happened. i also tested the fan relay by swapping it with the A/C relay, still no change.
the fan connector in the engine harness has a black (GND) and a light green wire, which is going to the fan relay. ground was tested good. can't think of anything else than the wires to the relay or ECU, or some blown fuse. i forgot to mention that when i tried the first time by pulling the CTS there was a spark at the fan connector and a short movement by the motor, that was all i ever got out of it save for hooking it up to the battery for testing.
any suggestions or hints?
btw, does the ECU still close the fan relay circuit if it notices that no load is applied (electrical load like when the fan is on)?
