Old 11-05-2009, 04:22 PM   #1
Non-popping up headlights
My Ride: Daytonas
This is the '89 Daytona ES in question. I "think" I had this same problem early on when I got the car, the headlights not going up/down. I pulled the module and reseated the connector and it worked ever since. So I did the same thing again this time and no luck. I then swapped to a different module and still no luck. I heard and felt the module(s) clicking away when I pull the switch, but the headlights stay down. I checked all the fuses, replaced one, but I don't think it was on the headlight circuit, nothing. I was thinking a common ground maybe, I pulled and cleaned the ones on the inner fender behind the battery and on the pass side by the evap canister, nothing. Hand cranked the lights up and down, motors aren't stuck.
So, before I start chasing wires, any known trouble spots I should take a look at first, any other components is the circuit? BTW, the lights work.
ChargedDust is offline
Old 11-05-2009, 10:14 PM   #2
Re: Non-popping up headlights
My Ride: 92 Iroc R/T Red
Engine: TIII
have you read these?
Headlight Module Repair Part 1(Illustrated)
Headlight Module Repair Part 2(Illustrated)
Tim
charger R/T is offline
Old 11-06-2009, 01:13 AM   #3
My Ride: Daytonas
Yeah, that's a last resort, wanna try thre "easy" stuff first.
Old 11-06-2009, 02:50 AM   #4
My Ride: 89 Daytona
Engine: 2.2 T2
Feedback: (8)
Images: 17
switch bad or corroded?
jory is offline
Old 11-06-2009, 06:34 AM   #5
I have the wiring for you, just will not be able to post it until tomorrow morning.
Jan
1990 Daytona Shelby VNT
NAJ is online now
Old 11-06-2009, 09:49 AM   #6
Engine: TIII
The stuff you think is the easy stuff most likely will turn out to be a waste of time. With all the threads on these headlights not working and the thread starters then posting how the module repair fixed it. To me the module repair is the easy repair. Also you posted you reset the plugs and they worked for a while. You may have just flexed the board enough to get it working again and the plug contact was good to begin with. Just my thoughts. If you want to try easy flex the box while operating the lights and see if jumps starts it.
Tim
Old 11-07-2009, 01:23 AM   #7
My Ride: Daytonas
swapped the module with one from one of the other cars it woeked fine, so the original module and the spare were both bad. Gonna tear into the module over the weekend.
Old 11-07-2009, 12:38 PM   #8
Going Hybrid All Around
1983Rampage's Avatar
My Ride: 1989 Daytona ES
Engine: 2.5l T2
Feedback: (13)
The repair on the module is easy. I was having the same problems and I tore the module apart and actually repaired all of the spots that looked to be possible issues. It then worked like a charm.
Which would you rather have, go fast goodies or shiny shoes?
Your feet may look good, but if your engine blows up, you ain't going anywhere.
1989 Dodge Daytona ES - T-top - 2.5l T2 with A555
1983 Dodge Rampage - 2.2l T2 with A525 (RIP)
1984 Dodge Rampage - 2.2l Carb with A525 (RIP)
1987 Dodge Shelby Charger GLHS #782 (RIP)
1987 Dodge Lancer ES - 2.2l T1 with A413 (RIP)
1983Rampage is offline
Page generated in 0.16023 seconds with 9 queries
