Old 01-06-2005, 11:51 AM   #1
Heater not blowing air
Hi everyone! '88 daytona shelby here. I have a problem with the heater not blowing air recently. It doesn't happen ALL the time, just some of the time (sometimes I turn the car off & when I restart it later it will work) & mainly when it's pretty cold out. It's not fun driving home in -25 without any heat!
Do you think it's a loose electrical wire? Or could it have some moisture buildup and when it's cold, it freezes? Maybe the heater motor just isn't working?
Any help would be appreciated. Thanks a lot!
ShelbyPrincess is offline
Old 01-06-2005, 06:31 PM   #2
It sounds like you are experiencing problems with the motor or wiring. You do get hot air when it does work, right?
Dig around and see if you have any bad connections around the blower motor or see if you can find a known good one to swap in there.
Sounds like you've got the idea on possibilities of what could be wrong. Now go get in there and find out!
ZEROLAG is offline
Old 01-07-2005, 09:18 AM   #3
Yeah I do have heat when it works. That's what I was thinking... probably the wiring. I'll get in there this weekend when I have the use of a garage so I can check it out.
Thanks for the tips!
Old 01-07-2005, 12:09 PM   #4
My Ride: '88 Sundance
Engine: '89 2.5 TI
I was having the same problem with my '88 Daytona Pacifica. The heater fan would work sometimes, but more often it wouldn't. Turned out to be a loose connection in the blower wiring under the dash on the passenger side. I found the bad connection by simply wiggling the wires, shoved the connector all the way together, and haven't had a problem with it since.
HTH,
Tony
tonyz2897 is offline
Old 01-07-2005, 12:24 PM   #5
Are you talking heater fan or actual heat, your story is a little confusing?
Old 01-07-2005, 12:44 PM   #6
My Ride: 88 sundance
yea if its no heat its one thing, but if its the motor int. working its another
jdawg is offline
Old 01-07-2005, 12:55 PM   #7
heater fan
bmxrider is offline
Mortgages | Mortgages | Loans | Loans | Personal Loans
Page generated in 0.35685 seconds with 13 queries
