02-05-2005, 12:41 AM
My Ride: 1991 Daytona Shelby
Engine: SOHC 2.5L
Originally Posted by wheming
the coolant temp sensor at the t-stat is not the same one that reads to the temp gauge, right?
You are correct Wayne, with the 180 t-stat and having a 1/16 hold drilled through it she shouldn't have any problems, if your still worried install a 160 degree t-stat.
P.s. It sure is good to know Gus'(R.I.P.) Slugmobile is in good hands
02-07-2005, 08:28 PM
My Ride: 92 Iroc R/T Red
Engine: TIII
I've read some guys tie a wire in on the ground wire from the computer to the relay and put in a toggle switch so they can turn it on when they want. Instead of the toggle switch locate a temp sender that is an on off type (not variable resistance) and set for 195 and install it in a coolant passage. I have a TIII so I don't have an 8v here to look at but I think I have read there is a plug near the thermostat housing you can use. Most trucks use shut down systems and there senders are on off not variable like the senders used on gauges and they can be had in all temp ranges.
Changing the fan schedule is a good idea. I just had to change the thermostat in my lebaron it was stuck open and even with it open in my garage it would at idle get high enough to turn on the fan at 210. So even with no thermostat it still runs at the computer setting not the thermostat setting.
You don't want to cut the wire from the computer because you still want it to turn on with the A/C.
If you need more info PM me or post here.
Tim
02-08-2005, 07:10 AM
Engine: 2.5L
Usually thermal resistors run in the range of 300 to 400 ohms. Measure yours once it warms up. You can do this by disconnecting it, using an ohm meter to check the resistance from the main terminal stud to ground.
You will want to make it pretend that it is running hotter then it really is. This means you need to reduce the resistance of the temperature sensor (thermistor - variable resistor that is effect by temperature. uses a non linear curve that is inversly proportional to the temperature).
So what is a good way to reduce the resistance? A resistor in a parrallel circuit is the easiest. You would connect this resistor from the temperature sensor wire, to ground. Since it is in parellel, it needs to be of very high resistance to drop the overal resistance read by the computer just a little in hopes to estimate a good temperature drop.
The equation for parallel resistance is as follows:
Rt^-1 = R1^-1 + R2^-1 + R3^-1 + ..... + Rn^-1
Rt = Total Resistance
R1, R2, R3, Rn = are the resistors in parrellel. As you can see, you can have as many as you want.
Lets assume that you measure R1=350ohms, and you want to reduce the resistance by 20ohms to achieve Rt=330ohms.
330^-1 = 350^-1 + x^-1
x = 5775 ohms.
Since the nearest common resistor is 5800 ohms, you would need a Green, Gray, Red resistor. If you let me know what the resistance when it warms up, and just before it warms up, I can get you all the information needed to ensure proper tempature control.
Frank
02-08-2005, 11:36 AM
My Ride: 85 GTS, 3 87 GTS, 89
It won't work. When a hose blows and steam comes out, and the engine starts rattling, she will think the muffler is falling off and drive it home for you to fix. Then you will be even more STEAMED at her after all the work you did.
"Incompetence is a state of mind caused by too many years on computers".
Reason: insanity
02-08-2005, 04:54 PM
#12
My Ride: 1986 Plymouth Horizo
Engine: 2.2 Turbo
I use a fan controller from Painless wiring... threads into the tstat housing, turns the fan on at 185, and off at 170.
02-10-2005, 08:54 AM
#14
Engine: 2.5L
No problem. E-mail me anytime, I dont mind. I can get that faster then checking TD for updates or questions.
Frank
