Old 02-05-2005, 03:14 PM   #1
Boost gauge lighting?
My Ride: 89 Spirit ES
Engine: 2.5 STD TII 20psi
I have a mechanical boost gauge in my car, how do I wire my lighting for it? It has two wires, ones a black, and ones a black and green.
Thanks,
-Bryan
Dave is offline
Old 02-05-2005, 05:49 PM   #2
looneytuner's Avatar
My Ride: 85 GTS, 3 87 GTS, 89
I had to pull the instrument cluster, so I just traced the light circuit for the bulbs to the 2 plugs. That way it will dim with the instruments. The one connector has the positive light pin and the other has the negative pin.
looneytuner is offline
Old 02-05-2005, 07:29 PM   #3
I just jammed it into the fuse panel in a very half assed manner . Jammed it into to the sameone as the dash lights and it dims along with them.
DarkWolf is offline
Old 02-06-2005, 09:03 PM   #4
Easy wiring for light
My Ride: Caravan
Engine: 3 Liter SOHC
Just connect one to ground and one to a switched ignition wire. You will always be able to see the boost gauge. Or, you can pull your cluster, solder two wires to any backlight circuit on the cluster and wire to the boost gauge light.
kandamotorsport is offline
Old 02-06-2005, 09:05 PM   #5
Una
My Ride: Horizon GLH-T
Engine: 2.5L Turbo
There are a dozen lights in the center console you can easily get power from. I just put an aftermarket boost gauge into my Daytona last night. Was in such as rush that I spaced the need to wire up the light.. heh, kinda sucks trying to watch the boost gauge with the dome light on at night.. haha..
Una is offline
Old 02-06-2005, 09:27 PM   #6
My Ride: 87 Shelby Z
The radio illumination wire is easy to get at also.
Benji
bfarroo is offline
Old 02-06-2005, 11:48 PM   #7
i hooked into my radio fuse. making them dim would be sic, im gonna have to try that
TurboShadowES is offline
Old 02-06-2005, 11:55 PM   #8
My Ride: 86 shelby charger
i just jammed mine into my fusebox also, but have to try and put it in the dash lights fuse ima go try that lol brb
sup3rfr3ak is offline
Old 02-07-2005, 12:20 AM   #9
My Ride: 1985 Shelby Charger
Engine: 2.2 Turbo
I used the illumination wire to the stereo
Phreakish is offline
Old 02-07-2005, 07:43 AM   #10
So I can hook up any one of those two wires into lets say the radio lumination wiring? Just like splice them together? And for the ground on the last wire,e I can just hook that up to the firewall on the passenger side?
Thanks,
-Bryan
...sry for all the questions, Im not an electrition though.
Dave is offline
Old 02-07-2005, 12:17 PM   #11
My Ride: 1987 Shelby CSX #694
Engine: 1987 2.2L
The illumination wire is the orange wire that goes to anything that lights up at night when you turn the headlights on. You can ground it anywhere on the chassis. Just remember that not all metal parts of the dash actually connect to the vehicle chassis. Take a hint from the radio ground strap.
minimopar is offline
Old 02-13-2005, 02:42 AM   #12
Engine: 2.2 Turbo
I spliced (soldered) into the illumination wire (the orange one as stated above) and then grouded it behind my console on my '85 charger (one of the screws that holds the center console to the dash). Works 100% so far, and is nice and clean. Even installed the gauge in the 'deleted' a/c ducts behind the steering wheel. Now I just need to install a little potentiometer to the gauge so I can adjust its brightness to match my other gauges (or clean up the dimmer to make my dash a little brighter, or renew the green light covers on the cluster).
Mobile Phones | Loans | Free eBooks Download | Fish Tank Help | Loans
Page generated in 0.38755 seconds with 13 queries
