02-08-2005, 11:03 PM
Ideally a scan tool would really help. I recently bought a 1992 grand voyager ($150) that over heated and had tons of parts thrown at it...New radiator, new cooling van, new water pump and thermostat. so I hooked up my snapon MT2500 and activated cooling fan relay... relay clicked, no fan. did a little RTFB (read the factory book) and found that there is a fuseable link in the system.... found the fuseable link wires and sure enough one was fried. spliced in a new fuse wire (actually a used one from a junk car) and it works great... ended up selling the van 3 months later for $1000 pretty good turn around for a free wire and 30 min of work.
I would recommend trying this. start the car and then disconnect the coolant sensor, this will energize the cooling fan circuit. see if the relay clicks. if so use a test light or multimeter to check for power out of the relay (check power into relay also) there will be 2 hot wires with the key on. one hot wire at all times (this wire is the power feed from the fuse link). try jumping hot wire to fan wire to check for circuit power. check relay... energize relay and check for continuity across the fan power circuit...theres just a few things to try
