Old 02-10-2005, 05:22 PM   #1
why do TD speed sensors blow
My speed sensor breaks like once a year. anyone have any ideas as to why? the car has a quaife and a solid bobble strut so that might have something to do with it.
QKsilverF1 is offline
Old 02-10-2005, 08:33 PM   #2
My Ride: 2000 GMC Sierra
Engine: 5.3L V8
How are they broken?
I've got a solid bobble strut and I've never broken the same one I've had in my car for years.
cybermrc is offline
Old 02-10-2005, 09:07 PM   #3
the sensor just craps out, my speedo will bounce all over the place, then i replace it with a new one and its fine
Old 02-10-2005, 09:31 PM   #4
My Ride: 1987 Shelby CSX #694
Engine: 1987 2.2L
You might want to make sure the pins on the connector are making good contact and the plug isn't soaked in oil. They don't last long because they are just a glass-enclosed mechanical switch, but they should last longer than a year.
minimopar is offline
Old 02-10-2005, 09:48 PM   #5
What brand are you using?
Is the case or sensor housing cracked at all?
Old 02-11-2005, 01:45 AM   #6
im using a mopar sensor, last time i had the tranny out nothing was cracked. the oil pan gasket leaks a lil so it might be oil getting on it.
Old 02-11-2005, 11:58 AM   #7
Weird, very weird. How the heck does the oil pan get the sensor covered, the sensor is higher up?
I would do what Russ suggests and check your wiring and connector!
Old 02-11-2005, 04:00 PM   #8
where the oil pan meets the block is higher up than the sensor
Old 02-11-2005, 05:06 PM   #9
My Ride: 91 'Tona Shelby
same as cybermrc
orion is offline
Old 02-11-2005, 06:42 PM   #10
My Ride: 1985 Shelby Charger
Engine: 2.2 Turbo
can be lots of things - I opened mine up and redid the internals on my 2 wire sensor. The wires broke off mine, so I resoldered them to the glass sensor inside, and cleaned up the 'flying magnet' in there too (was quite rusty, dirty, grimey, etc).
I suspect that if the speedo is jumping around, that the magnet might be turning on the shaft, I was able to turn mine fairly easily, so I glued the sucker in place real good with some superglue (model airplane type). Havn't had a problem yet...
Phreakish is offline
Old 02-11-2005, 08:18 PM   #11
Engine: 1987 2.2L
You can sometimes eek a few more miles out of one by bending the metal tab inside to bring the contacts closer to the magnet.
Old 02-12-2005, 01:00 AM   #12
My Ride: 85 GLHT, 87 ShelbyZ
Why not just install the later 3 wire sensor??
GLHNSLHT2 is offline
IT247 Computer Hardware | Best Credit Cards | Mobile Phones | Mobile Phones | Best Credit Cards
Page generated in 0.40058 seconds with 13 queries
