Old 02-12-2005, 03:52 PM   #1
Dead odometer, 90 Daytona VNT
Hi all, looking for some help here. Have a 90 Daytona VNT with a working speedometer but a dead odometer. Have tried 2 different speedometer units, same problem. Could this be a body control module problem? Any help appreciated, thanks!
racer-xerols is offline
Old 02-12-2005, 03:58 PM   #2
My Ride: 90 Shadow ES VNT
Engine: 2.2l 135 CI
If it's the analog and not the digital, then you more then likely have broken or cracked speedo gears in the speedo itself. Thea gears are made out of hardened rubber that likes to crack over time due to the heat and moisture, etc. Only way to fix it is to have a shop make you some new gears, or you can always pull a unit from a junker and keep your fingers crossed.
90DodgeVNT is offline
Old 02-12-2005, 04:03 PM   #3
looneytuner's Avatar
My Ride: 85 GTS, 3 87 GTS, 89
One more time. The gears are at
http://www.odometergears.com/
The directions are at
http://www.backesfamily.com/TCProjects/
looneytuner is offline
Old 02-13-2005, 06:41 AM   #4
Junkyard speedos
My Ride: All of them
Engine: 2.1 T1
I saw a thread on Allpar awhile back about these units. I think 87 to 91 have this problem and Chrysler went to a different vendor or model in 92. Try one out of a 92 or 93 if going that route. I have run into the same thing. Put a 91 in a 90 and it didn't work. Problem on both is gear has crumbled.
mike mckay is offline
Refinance | Christmas Lingerie | Loans | Remortgage | Cell Phone
Page generated in 0.35030 seconds with 13 queries
