02-18-2005, 12:24 PM
Yes, I did this to my Omni. I took a motor from a CSX and did the transplant. I must have been nuts, because i had a time deadline of 1 week to complete the swap.  I put in 12 hour days for six days straight to get it running. The fuel pump can be fit into the stock carb tank, but the sender has to be modified. I think I remember welding a return line into the sender (cant quite remember the specifics). You have to get creative. You will have to get the right axles for the car depending on the tranny you use. Look at the transaxle section on thedodgegarage for more info. You may also have to weld a bracket on for a bobble strut depending on your tranny choice. The biggest PITA is the wiring. EVERY wire has to be transplanted from car to car. Most of my dash still does not work. Mostly because I have not taken the time to complete it yet. My speedo works and Ive got an aftermarket tach and other key gauges, so I havent really had the ambition to finish the dash. But the essentials were a pain....horn, wipers, heater, etc... Its a lot of probing around and looking at diagrams, splicing and cutting. Its doable, but a pain. Like I said, Ive had about 60-70 hours in just doing the basic swap.
Here's my car. Orinally a regular carb'd Omni:
http://www.turbododge.com/forums/att...achmentid=5097
