Old 02-19-2005, 08:32 PM   #1
Radio wire help
My Ride: '87 GLHS #369
Engine: 2.2 sohc
Images: 3
I need help with my radio wireing. I am hooking up an aftermarket cd player in my '87 GLHS. I have searched through the forums and can't find any that match my car. Here is the breakdown.
grey plug-
red/white
red
orange
yellow/black
light green
black/white
black plug-
blue/red
brown/red
purple
dark green
blue/white
brown/yellow
both plugs have an unused pin...only 6 out of seven are there
If anyone can help me out, I would appreciate it
wrenchbreaker is offline
Old 02-20-2005, 02:48 AM   #2
does the head unit have a diagram on the top? i can probably help you out since i had to run new wire for my 82 dodge 400.
bmxrider is offline
Old 02-20-2005, 03:14 AM   #3
My Ride: '85 GLH
Hi,
Looking at the back of the radio, where the Gray plug goes in:
________!_______
! 7 6 5 4 3 2 1 !
1 - X1 - Battery 12v feed
2 - X12 - Acc/Run 12v ignition
3 - E2 - Illumination
4 - L7 - Park Lamps
5 - right door speaker (return) (internal jumper to black plug 1)
6 - left door speaker (return) (internal jumper to black plug 2)
7 - Not used
Now looking at the black plug,
________!_______
! 7 6 5 4 3 2 1 !
1 - Right Rear speaker (return)
2 - Left Rear speaker (return)
3 - Right door speaker (feed)
4 - Left door speaker (feed)
5 - Right rear speaker (feed)
6 - Left rear speaker (feed)
7 - X60 feed - if used (voice alert)
Hope this helps.
To wire your aftermarket deck, you'll likely only need 12v Constant, 12v Ignition, the antenna input, a ground strap and speaker wire.
Best of luck.
Later,
Craig
Craig is offline
Old 02-20-2005, 10:38 AM   #4
BFnGA's Avatar
Or for about 7-8 dollars you can buy a harness adapter that will wire up to your aftermarket deck and allow you to plug it directly into the factory plugs . And they come with instuctions
BFnGA is offline
Old 02-20-2005, 04:56 PM   #5
Engine: 2.2 sohc
Images: 3
I bought one of those adapters and it turned out to be compleatly wrong. Oh well! I will get it all finished up today with the input I recieved here. Thanks folks
Old 02-22-2005, 12:43 AM   #6
Engine: 2.2 sohc
Images: 3
Well...I got everything hooked up and working great. What is up with the park lamp wire? Does this need to be grounded for the parking lamps to work? Now I don't have front left park lamp or side marker after hooking up the radio. WTF?
Old 02-22-2005, 06:37 PM   #7
Engine: 2.2 sohc
Images: 3
bump
Old 02-22-2005, 07:38 PM   #8
My Ride: TIII R/T
Engine: 2.2L TURBO III
Feedback: (10)
I never saw a radio with parking lamp wiring, i know it have a dimmer for the display, thats the orange wire or orange and white usually, its not used with aftermarkets. Parking lamps have nothing to do with the radio and arent even in the harness with the radio
xtrempickup is offline
Old 02-22-2005, 08:42 PM   #9
Engine: 2.2 sohc
Images: 3
I've seen 2 different threads saying that one of the wires is parking lamps.
Mortgage | Home Insurance | Free eBooks Download | Indoor Flag Pole Sets | Myspace Layouts
Page generated in 0.34032 seconds with 13 queries
