Old 02-20-2005, 09:45 PM   #1
Lights flicker at 5 psi of boost?
My Ride: 87 GLHS & 73 Cuda
87 GLHS with stage II logic module. As soon as I reach 5 psi of boost, the lights flicker. Is there something drawing power as boost builds?
tvanlant is offline
Old 02-20-2005, 10:21 PM   #2
That would be the cooling fan coming on. A slight flicker is ok, but if you notice your voltage gauge dropping too low, you might want to double check your charging system.
bill2 is offline
Old 02-20-2005, 10:58 PM   #3
Do the fans kick on under boost? I can make the lights dim on and off by getting on and off the throttle until it goes past 5 psi. Its not a slight flicker either, the power gauge will bounce when this happens.
tvanlant is offline
Old 02-20-2005, 11:08 PM   #4
My Ride: 91 Spirit R/T
Engine: TIII
That's not unusual, mine did that all the time. The GLHS logic module turns the fan on around 3-5 psi since the radiator is so small on those cars.
86Shelby is offline
Old 02-21-2005, 12:23 AM   #5
Interesting, you learn something new everyday.
On the subject of radiators, do you know where I can get an aftermarket radiator? I the local parts store order two radiators for the car and both were wrong. They claim that no one makes them.
tvanlant is offline
Old 02-21-2005, 12:31 PM   #6
i had the same problem, turned out to be my ground under or near the batterybox(black wire screwed to the sheetmetal inner fender.)
Carl
turboking is offline
Word Definitions | Mortgages | Modded Xbox | Free Image Hosting | Books
Page generated in 0.33839 seconds with 13 queries
