Old 07-09-2006, 08:38 AM   #16
wiper motor blues
My Ride: 85 Shelby Charger
Engine: 2.2 Dodge
WOW!!! YOu guys are awesome. I had the wiper problem with the 85 Shelby Charger I am restoring. I went out just now and ran a ground to the wiper motor body, VIOLA! It worked. I then started loosening mounting screws to see which one would do the deed. It was the lower left mounting bolt ( as viewed from the front of the car). Yay, Problem solved, Thanks a bunch, jeff1234
jeff1234 is offline
Old 07-09-2006, 10:32 AM   #17
My Ride: 92 Iroc R/T Red
Engine: TIII
That is just a temperary fix. Look at the bolt you turned to get it to work. It should have a thin strap going from the stud to the plate the motor mounts to. It is held on to the plate with a rivit. That is where the connection goes bad. Loosing the nut and tighten it again shifts the strap and gets it working again but it will fail again. To fix it once and for all run a wire from the plate to the firewall. I have used self drill screws in both the plate and firewall to hook up the wire just use short ones. Or drill small holes to run sheet metal screws in.
Tim
charger R/T is offline
Old 04-07-2007, 10:47 AM   #18
Still around, just workin
Turbo Joe's Avatar
My Ride: 87 csx # 175
Engine: 2.2 T III 16V
Images: 22
Ok, I've cleaned up the thread. Please try to post helpfull information.
Faster than a speeding ticket!!... someday
1987 SHELBY CSX #175 TIII POWERED ALL OUT DRAG, Possible street duty again?
1991 SPIRIT R/T TIII stock and i popped the headgasket..
Turbo Joe is offline
Old 10-04-2007, 06:36 PM   #19
Re: Wiper Motor Blues
My Ride: 1986 Shelby Omni
Just wanted to say thanks for this thread. I thought I had a bad wiper motor, but when I replaced it the new one didn't work. I found this thread, and hooked up a grounding wire. Now the wipers work again. Thanks.
rhett314 is offline
CitiBank Credit Card | Myspace Layouts | MPAA | Loans | Credit Card Consolidation
Page generated in 0.23787 seconds with 13 queries
