Go Back   TurboDodge.Com - Turbo Dodge forum for Turbo Mopars, Shelbys, Daytona, SRT-4, PT Cruiser, Omni and more! > Turbo Dodge Technical Chat > FAQ Section
FAQ Section Turbo Dodge FAQ section with answers to the questions we've all asked before.
Old 08-23-2004, 03:23 PM   #31
Originally Posted by glhsken
Unfortunately, that's beyond what I've tried.. I had GLHS modules lying around so I swapped them in.
No Idea if the 86 T1 module will work with the new set-up. I do know the 86 modules are pinned to handle it... Not sure if the logic is there though.
Another Note:
The fuel tables for the 86T1 are designed for the Log manifold. On the log, due to its poor flow characteristics, 2 of the injectors fire more fuel. When swapping to a t2 style intake, you will end up with either 2 rich, or 2 lean cylinders.
OmniSRT4 is offline
Old 02-08-2005, 12:29 AM   #32
My Ride: 1978 Dodge stepside.
Engine: 318 Turbo Project
Okay, I printed out the LM's from the 86T1 (which I have) and the 87 T2. On the t2 LM, there's numerous "pins" that aren't used in the 86 T1 LM. Can I just get extra wires and solder these new connections? Also, on the "blue" 86T1 connector, pin #4 goes to the "power loss lamp output", but on the 87T2 LM, is says "speed control solenoid vacuum output". Do I have to change these? Also, the 86t1 blue connector pin #6 says "EGR solenoid output", while the 87T2 blue connector pin #6 says "Speed control solenoid vent output". Do I need to modify this?
So basically, besides adding to whatever pins aren't used on my 86 LM to their designated purposes on the 87 T2, do I need to change anything else?
Michael
MoparFreak is offline
Old 02-08-2005, 06:47 AM   #33
br549
Michael,
There are some threads on this site which have copies of the actual wiring diagrams. If you do not have the 86T1 and the 87T2, I suggest you get copies of them. I found it confusing that the labeling and terminology for the years was slightly different yet provided similar function. Can someone who cruises this site regularly make the connection? If no one helps you in the next few days, I will scan the diagrams in my manuals and send them to you.
Regards,
Bernard
Old 02-08-2005, 07:22 AM   #34
My Ride: 1987 Shelby GLHS 189
Tha ONLY changes you need to make are those listed in the beginning of the thread. From memory 4-6 swaps/additions.
NOTHING else needs to be changed.
glhsken is offline
Old 02-08-2005, 07:05 PM   #35
Okay got it. However, I don't need the 87 LM? I can just use my current LM correct? Thanks.
Michael
Old 02-08-2005, 08:07 PM   #36
I was referring to using an 87 code based module. ALLLL "L" bodies are 86 based
glhsken is offline
Old 02-09-2005, 08:46 PM   #37
My Ride: 85 GLHT, 87 ShelbyZ
Michael
you have to use an 87 T2 module to run 87 electronics. Or if you have an 87 T1 module you can have that reprogrammed. I guess you could go with a GLHS setup as you could then keep 86 electronics. I'd go 87 myself at least. Or SMEC the car.
GLHNSLHT2 is offline
Old 02-24-2005, 07:35 PM   #38
Old School Hot Rodder
85lebaront2's Avatar
My Ride: 1985 LeBaron Vert
Engine: MOPAR 2.2L
If anyone wants it, I have several Excel spreadsheets I made up when doing my T2 conversion. Mine was more interesting, I went from a 2.6L to the 2.2 T2. PM me and I can send them.
Bill Vose
1986 Turismo 2.2 (race car)
1989 Grand Caravan 3.0L (for sale)
1993 Grand Caravan 3.3L
85lebaront2 is offline
Old 03-23-2005, 11:17 AM   #39
My Ride: shelby charger
Engine: 2.2T
hey I have just coverted my 87 shelby charger to t2 status all i did was ad two wires for the AIS I didnt move anywires around and I am running really rich, I am running a Stage two GLHS from Mopar for a computer, did i mis a dew things,
glhsdrew is offline
Old 04-24-2005, 08:22 PM   #40
My Ride: 87 LeBaron Convert
Engine: 2.2 Turbo 2
I don't have any newly-un-used pins in my LM connectors going from 87 T1 to 87 T2... I need to connect the 2 new wires for the AIS at the logic module - I'd like to put it into the connector so I can disconnect the logic module without having to un-solder a wire.
Anybody have any suggestions? I tried pulling one of the "pin recievers" (female type - opposite from the PIN itself) from a chrysler wiring harness for a cd-player but it wouldn't slide all the way into the connector.
Mike
89DodgeSpirit is offline
Old 04-28-2005, 01:51 AM   #41
Engine: 2.2 Turbo 2
I found that the pins from an AT Power source (older one) power connector are perfect. I happened to have an old power source in my other vehicle - I got to looking at the connectors and the actual motherboard power connector pins looked perfect.
I pulled a couple out and they worked great - so for any of you out there with extra old power sources that are bad or you don't need look there for your pins! =)
If anything - Turbo Dodge people are VERY resourceful!
Mike
Old 05-15-2005, 11:21 AM   #42
the 2 extra wires for the AIS motor
i am lost and need help. the 2 extra wires, where do you splice them into? what color wire??
bmxrider is offline
Old 05-15-2005, 09:26 PM   #43
als
My Ride: 89 caravan es t1
Engine: 2.2 garett/ 3 inch e
you don,t splice them in they go to the LM you add them and swap 2 other ones, but it,s been 3 or more years so i can,t tell you what # too add them too. i have it up somewhere so it you don,t find it lmk i will hunt it down ok. ALS
als is offline
Old 05-16-2005, 01:54 AM   #44
whats the LM? sorry, i know its a dumb question!
bmxrider is offline
Old 05-16-2005, 05:46 AM   #45
als
it,s not / on 87 and older the computer was in two parts / one the PM or power moduale is under the hood, what the air box runs from/ the other is the logic monduale it,s on the right side kick pandle/ thats the brain there are a red and a blue plug/ thats the ones u add/and move wire to and from ALS
als is offline
New York Hotels | Best Credit Cards | Free Credit Score | Free Ringtones | Car Loan
