SHL1, SLH2, SLH3 Caravan 60mm Caliper Brackets - Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more!
Parts For Sale Post your turbo dodge parts for sale here. TD-specific items only.
 4Likes
  • 1 Post By ILIKESHELBYS
post #1 of 11 Old 01-06-2017, 09:26 PM Thread Starter
- OFFICIAL GEARHEAD -
ILIKESHELBYS's Avatar
My Ride: SC/GLHS(2)/CSX
See the complete description in my turbo Dodge Parts list:
Miscellaneous turbo Dodge Parts for Sale
I have three sets of minivan/Caravan/Voyager (1985-1989) single pin, Kelsey Hayes 60mm caliper brackets WITH factory mounting hardware for sale. As pictured below.
$50.00 Shipped to your door.
Lower 48, Alaska, Canada, Hawaii, Puerto Rico additional postage will be required.
ILIKESHELBYS is offline
post #2 of 11 Old 01-08-2017, 02:16 AM Thread Starter
Re: SHL1, SLH2, SLH3 Caravan 60mm Caliper Brackets
One set is sold, I now have only two sets remaining.
post #3 of 11 Old 01-08-2017, 02:36 PM
My Ride: GLHS 958
Engine: 2.2 Turbo II
So the other parts to do the front brakes are all available in the aftermarket?
INSATANSSEAT is offline
post #4 of 11 Old 01-08-2017, 04:39 PM Thread Starter
Yup, Rockauto.com as well as any major auto parts chain has them all. You would need the 60mm calipers, the 260mm rotors, your choice of Kelsey Hayes brake pads and at your option I might suggest you also replace the rubber hose that goes from the caliper to the body.
You can save an additional 5% at RockAuto using their discount code.
RockAuto.com 5% Discount Code: 883A18990D8EF5
Expires: March 22, 2017
INSATANSSEAT likes this.
post #5 of 11 Old 01-08-2017, 06:27 PM
My Ride: 86 Daytona Turbo Z
I was always under the impression the SLH brake setups included 282mm front rotors?
Marc is offline
post #6 of 11 Old 01-08-2017, 06:57 PM Thread Starter
...and you would be mostly wrong.
The complete recipe for any of the SLH packages can be found here:
Get Educated ► SLH Brake Upgrades
The SLH upgrades were originally intended to be bolt on options for the early cars like from 84-89, mostly the L-bodies like Omni/Charger/Rampage/etc, but early drum brake cars like Turbo Z Daytona, Chrysler built Laser, and Lebaron are also candidates as well as cars w/o Kelsey Hayes calipers (just for ease of single pin service of front brake pads).
The 11" front rotors would require the complete spindles, calipers, brackets, pinch bolts and brake lines off a later model car like a IROC Daytona for example, and if installed on an L-body would require modifications (like machining, and/or grinding/spacers/different bolts) to the strut or spindle or both and depending on the wheels on the car, might require different 15" or even 16" pumpers or anything else that fit to clear the calipers and brackets. None of the 14" wheels are going to fit.
Boost on...
Steven Seale
QUICK-FIT SHIFT RODS★ ~ ★A525/A555 CONVERSION BRACKET
QUICK-SHIFTER ★ ~ ★REBUILT TRANSMISSIONS★ ~ ★PT LIFTERS AND SHIMS
PROUD TO BE AN ACTIVE MEMBER OF THE TURBO DODGE ENTHUSIAST COMMUNITY
post #7 of 11 Old 01-08-2017, 07:03 PM Thread Starter
INSATANSSEAT: Here are some of the options for calipers, pads, and rotors from Rock Auto:
ROTOR $12.21 EACH
WAGNER BD61947 Info
Front; 5 Stud Wheel; 260mm Dia. Rotor
BRAKE PAD $7.64
WAGNER MX259 {#LT259} ThermoQuiet Info
Front; w/Kelsey-Hayes Caliper; OE Semi-Metallic
CALIPER LEFT $27.29
A-1 CARDONE 184180S {#4313245} Reman. Friction Choice Caliper w/Installation Hardware Info
Front Left; with 1 Pin Mounting; with Metal Piston
CALIPER RIGHT $27.29
A-1 CARDONE 184179S {#4313244} Reman. Friction Choice Caliper w/Installation Hardware Info
Front Right; with 1 Pin Mounting; with Metal Piston
post #8 of 11 Old 01-08-2017, 07:50 PM
First off, the SLH packages was always regarded as physical larger rotors. How does larger caliper piston equate too more braking power? Where does the extra heat go? larger rotors has more braking leverage over a smaller rotor. The term is rotor to wheel diameter ratio. The only thing a larger caliper piston can do is reduced pedal effort. Still the same brake pad, still the same rotor.
Second, who runs turbododgeparts.com?
Marc is offline
post #9 of 11 Old 01-08-2017, 09:40 PM Thread Starter
MEMBER MARC: This is a for sale thread and I would appreciate you following our forum etiquette and not hi-jacking my post to debate the physics of brake hardware. You're original post regarding the use of 11" rotors as part of the SLH brake upgrades was simply incorrect. I merely pointed you or any other member that your misinformation may have caused confusion for, to a resource so you could do your own research...and I provided you some additional information in-line on the 'why' the 11" rotors are not used in SLH upgrades.
Please open your own post in the brake forum if you want to solicit member comments on your brake physics topic. I'm sure it would be a topic of interest and just the sort of topic many would comment on.
83scamp likes this.
Boost on...
Steven Seale
post #10 of 11 Old 01-09-2017, 05:48 PM Thread Starter
A second set of the brake caliper brackets is sold. I have now only ONE set of the SLH1, SLH2, SLH3 Caravan brake caliper brackets remaining.
post #11 of 11 Old 01-11-2017, 03:29 PM Thread Starter
All the brackets are sold now. I am currently now out of stock on this item.
Human Verification
