USA Lots of TD parts - Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more!
Parts For Sale Post your turbo dodge parts for sale here. TD-specific items only.
post #1 of 14 Old 08-22-2012, 04:52 AM Thread Starter
My Ride: 92 Iroc R/T
Lots of TD parts
Need the money for other projects. Buyer must pay shipping and PP fees.
TII ported/polished 1pc intake mani. Polished fuel rail (not professional but looks very nice), TII injectors, TB and all sensors. Does not include the Vac block or and blue hoses and T clamps. 135.00
Ported/Polished exhaust manifold- 85.00
TII turbo. Comes with 2.5 SV, O2, 2.5 DP, all lines and fittings shown in pics, W/G. has light shaft play I would use it myself if I needed it. Came off a running car. 250.00
TIII turbo with TI turbine housing notched to fit a TII application. has some slight shaft play (less than the TII). was told it came off a low mileage car, didn't smoke, didn't make a grinding noise, but didn't make boost since the W/G puck in the turbine housing fell off so the W/G never shut. I swapped the housing for a TI housing so it should solve the problem. Ported comp and turbine housing (exh mani was ported for this turbo), ported 2.5SV, new chrome adjustable W/G, Fabricated W/G bracket and brand new o2. Has modded fittings, turbine housing swapped to it will bolt onto any TII car. Factory lines will bolt directly on. 315.00
Ported TI garret Compressor housing. Sandblasted. $50.00
Complete G-head. Came off a running 85 TI with 12X,XXX miles. Includes everything from cam, cam gear, valves, etc etc. $100.00
1 pc VC $20.00
2 pc VC. Sandblasted and polished. 40.00
TII rad/IC combo. Includes fan and upper rad hose. came off a running car. $150.00
TII rad/IC combo. Includes fan and upper rad hose. Rad was patched, look at pics. does not include blue silicone hoses and clamps $85.00
TI garret turbo. Needs rebuilt, has shaft play. Includes W/G, both housings, fittings and lines seen in the pics. $45.00
(look pics of the TIII turbo)
TII garrett center section. Needs rebuilt and the compressor wheel is slightly damaged. $15.00
Strut Tower covers I have 3 pairs. 15.00 per pair.
Vacuum block, includes all fittings. $25.00
2 Log air intake set-ups. Both have a new air filter, one has a KN filter. 15 each.
Ported log intake. Close to gasket matched. Didn't wanna go too far. the intake was also opened up where the turbo outlet connects to the log. bare intake. $40.00
2 2.25 SV with DP one has multi wire o2 other has single. 15 each 25 for both.
Complete A/C set-up. Includes everything needed to add A/C to your car. 75.00 plus shipping
Racing Hart R5 Rims. discontinued. Tires are well used. Multi bolt pattern. 17in . Will get more info on these. 400.00
I'll add more parts later and I'll have pics up soon.
Thanks
Moe
moe44688 is offline
post #2 of 14 Old 08-22-2012, 01:45 PM
Meow!!
Turbomini's Avatar
My Ride: 87shelby charger
Engine: 2.2L TII
Images: 217
Re: Lots of TD parts
parting the lebaron out huh? other parts off that car going or you keeping them?
Turbomini is offline
post #3 of 14 Old 08-22-2012, 04:29 PM
Garrett Booster
My Ride: 84 Rampage, 85 SC
Is the BOV for sale?
Moparman1991 is offline
post #4 of 14 Old 08-22-2012, 07:09 PM
Legendary Driver
GLHNSLHT2's Avatar
My Ride: 85 GLHT, 87 ShelbyZ,
Those are Racing Hart's, not Rally harts :)
GLHNSLHT2 is offline
post #5 of 14 Old 08-23-2012, 02:45 AM Thread Starter
Yeah, finally got it running all good, had the turbo working fine, timed it right (after what seemed like ten times I was off by two teeth), got the rad patched up that i got from you. then after it ran for a minute it started to smoke. Smelled like it was burning oil. I suspect the rings, but have no way to prove it. I picked up that t2 motor so I'm rebuilding that it might go into the baron or hopefully a 5 spd.
And thank you glhnslht2! Fixed. I was close
Pm sent on the Bov
All prices are Obo. Also the port work on the intake is mild. Factory restrictions were removed but not completely cause I didn't wanna have to beg turbomini to weld it back up. Exh has much more time into it.
moe44688 is offline
post #6 of 14 Old 09-23-2012, 10:09 AM
My Ride: daytona
pmd
jeep89 is offline
post #7 of 14 Old 12-10-2012, 01:24 AM Thread Starter
Still have most of this, might be moving soon so need this stuff gone.
moe44688 is offline
post #8 of 14 Old 12-10-2012, 04:06 PM
My Ride: 86 GLH
Engine: Pieces
Are those Tona back seats in that Pik of the two turbos and if so are they fo sale
dodgeomni86 is offline
post #9 of 14 Old 12-11-2012, 12:25 AM Thread Starter
PM sent
moe44688 is offline
post #10 of 14 Old 12-12-2012, 11:40 PM Thread Starter
I put the good rad/IC in my car only one left is the patched rad.
moe44688 is offline
post #11 of 14 Old 12-22-2012, 01:56 AM Thread Starter
Took the t3 turbo apart and found oil in the turbine housing.
Bump, shoot me an offer guys, need some money for my Mexican magnum clone.
moe44688 is offline
post #12 of 14 Old 12-22-2012, 10:45 AM
Level 3 Supporter
4Daytonas's Avatar
My Ride: 84 Turbo Z, 91 Shelb
Engine: 2.2-2.5
I'd go $30 for the Vacuum block shipped.
4Daytonas is offline
post #13 of 14 Old 12-23-2012, 01:36 PM
Sent you a PM about some of the parts. Where, in Ohio, are you located?
Toledocapitals is offline
post #14 of 14 Old 12-24-2012, 05:56 PM
Boost is a good thing!!
Steve in Va's Avatar
My Ride: 86 GLHS #295
Moe
Do you still have these?
I'm looking for a drop in K&N Filter only. I dont need any of the TI intake setups.
Steve in Va is offline
Human Verification
