11-11-2012, 11:09 PM
Converted T2 Airesearch Rebuilt NO shaft play.
Garrett Booster
My Ride: 1992 Dodge Shadow
Engine: 2.2 Turbo 1
I'm selling my extra totally converted T2 Airesearch Rebuilt NO shaft play turbo. Turbo came off a 1985 Laser with 120K miles then it was rebuilt. Originally came with a 2 port vaccum wastegate which I switched to a 1986 1 port wastegate which holds 15 PSI shop air steady. As you can see I polished quite a bit and cleaned/used exhaust header white paint, cleaned coolant passages as well. Has not been used since rebuild, Intake adapter came from FWD performance. I have a Garret T2 which I'm gonna use so I have no need for this turbo. The second to last picture you can see it completely clears intake so you wont have any problem on installation, depending on your setup you might have to rotate intake compressor a bit more. Last picture shows Garret compared to Airesearch I'm selling. Swing valve is 2 inch. $250
I also have a brand new set of high RPM lifters for $60 never used from FWD performance (Have receipt to prove.)
and a VNT 2.2 Lebaron stock Intercooler for $60, Used.
If you have any questions feel free to call or text me. 1(408)761-2018 -Brian
