Thermostat spacer w/ two 1/8 npt ports - Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more!
Go Back   Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more! > Turbo Dodge Buy Trade Sell > Parts For Sale
Parts For Sale Post your turbo dodge parts for sale here. TD-specific items only.
Old 11-11-2012, 11:11 PM   #1
Hybrid Booster
My Ride: 90 Daytona ES
Engine: 2.5 Turbo 1
acannell is keeping the peace
This is an EXPERIMENTAL design that has never been tested!!
This design has never been tested or installed on a vehicle so it may or may not work, and if it doesn't work, there are no returns or refunds.
Please review the drawing and pictures and make sure this will work in your application before purchasing.
The material is 6061-T6511.
See the drawing for detailed dimensions! Briefly: hole diameter for the thermostat is 1.5", like the head. The ports are 1/8 NPT. The thickness of the adapter is 0.485". The ports are 0.64" apart center to center.
The front surface has a machined finish, but the rear surface is unmachined, but is free from any pits or deep scratches and so should hold RTV well I think, or you could just sand or something.
The entire part was milled with a roughing bit so it does not have a smooth finish and has ridges in the z-axis. I dont think this really makes any difference functionally and you could probably dremel it smooth or something.
The demonstration fittings in the picture are rather large so I think pretty much anything would fit.
The fittings ARE NOT INCLUDED and are shown only for demonstration.
The only thing included is the aluminum spacer.
Price is $45 + s/h ($7 USA, $13 canada).
Or you can bid on the auction at:
Thermostat Spacer w Two 1 8 NPT Ports for 80's 90's Chrysler K Cars | eBay
acannell is offline
Old 11-13-2012, 12:31 PM   #2
Re: Thermostat spacer w/ two 1/8 npt ports
Level 4 Supporter
GentleCowboy's Avatar
My Ride: 95 Lebaron vert
Engine: 3.0 N/A
Images: 10
GentleCowboy is keeping the peace
....and the purpose of this spacer is?
GentleCowboy is offline
Old 11-13-2012, 01:12 PM   #3
Hybrid Booster
Engine: 2.5 Turbo 1
i cant take credit for the idea, i just designed and machined it..
apparently some people need ports on the head for turbo coolant lines or senders and this is a desireable solution..not sure why they cant just drill holes in the thermostat housing and tap them..but a couple people seemed excited about it so there must be some purpose..theres a thread on it "free machining for all" or something
acannell is offline
Old 11-13-2012, 02:17 PM   #4
Level 4 Supporter
Engine: 3.0 N/A
Images: 10
If it is for the credit... ok good job. Coolant will not circulate between two ports at the same in/out level. one has to be at the water circulating pump and the other where you have it. The ID of the port though is less than the minimum required. So, good idea for practicing design but not for cooling the turbo. Keep trying and think broad range.
Old 11-13-2012, 03:42 PM   #5
Hybrid Booster
Engine: 2.5 Turbo 1
I'm officially not the one coming up with ideas. Check out the thread. If someone comes up with something I find interesting, I'll machine it and they get one free. This one I had no use for, but a couple people seemed really excited about it so I made one, but its for sale, not free, since I dont need or want it.
They seemed real sure that it needed to be thin, I'm guessing its for an L-body or something? I have craploads of space on my daytona, id make it 1" thick instead, but this is what they wanted. I'd be worried that a sender would hit the actual thermostat itself since the holes intersect that zone. Oh well long hair dont care. I defer to the minds who thought of it.
Yes the 1/8npt is probably too small for coolant. I couldnt fit bigger at 1/2" thick without making a thicker block for the threads and then necking down to go under the thermostat, and I dont have any thicker stock than 1/2" at the moment, so not this time!
I dont think the idea was ever to use both ports on the spacer for supply and return, obviously. But you could use both as return (or supply? i forget) and maybe end up with enough flow that way. If this one sells for something reasonable I may make one with the bigger threaded zone so a bigger fitting can be used. And maybe even switch bits and give it a finish!
Apparently someone wants it because it has a $0.01 bid, woohoo!
acannell is offline
Old 11-13-2012, 04:49 PM   #6
Level 4 Supporter
Engine: 3.0 N/A
Images: 10
I understand you're exited with the creativity. Don't take me wrong. The cylinderhead has already an outlet for the turbo cooling plugged with a 1/2" NPT plug. You're someone might see it as and idea.
Old 11-13-2012, 04:57 PM   #7
Hybrid Booster
Engine: 2.5 Turbo 1
Sounds like you didn't read the thread, heres apparently why they want it:
it would be for anyone that wants to put a gauge sender in or do a turbo swap that on the there none turbo head when they cant get the plugs out of the head for the turbo coolant lines
but yeah it does need to be only about 1/2" thick with the holes to the driver side or the bottom
wow it just jumped up to $5.00 with 2 bidders! I'm going to be ROLLING IN MONEY. Literally. I will go to the bank and ask for that shiz in quarters. U jelly?
It only took me about 4 hours to measure, draw, toolpath, and machine it..so i'm almost up to minimum wage in India...TOTALLY worth it IMNSHO
acannell is offline
Old 11-18-2012, 06:25 PM   #8
Hybrid Booster
Engine: 2.5 Turbo 1
The one on ebay sold for about $15 shipped!
I can make more of these on demand, so if you want one, just PM me and I will send you the paypal address to send $15 to. Give me 2 days to machine the part, and I'll mail it out to you USPS First Class.
acannell is offline
Old 11-18-2012, 06:41 PM   #9
Dr Doom
Dr. Johny Dodge's Avatar
My Ride: RUSTY DODGES &FORDS
Engine: 86 T1
Feedback: (16)
I know what you mean about the senders possiably hitting the t stat
Idono if the idea was to put it over the t stat or under it but , if I had a spacer to move the t stat away from the head slightly I would have been able to add another gauge sender to the bleed hole position on top of the t stat box
as it is now the t stat gets in the way of any sender that might try to fit the bleed hole
no idea now how much the t stat needs to be moved forward - but a spacer to accomplish that would be an idea
check out my for sale thread Toronto area body, interior, mechanical L,G,K
http://i36.photobucket.com/albums/e9/bubblebob88/0motm9.jpg
Dr. Johny Dodge is online now
Old 11-18-2012, 06:44 PM   #10
Hybrid Booster
Engine: 2.5 Turbo 1
Wouldnt it be the same as this adapter, just without the need for the two 1/8 npt ports?
acannell is offline
Old 11-18-2012, 06:48 PM   #11
Dr Doom
Engine: 86 T1
Feedback: (16)
ya , I just have no idea how thick it would need to be at this moment
it would only need to be thick enough to move the t stat forward of the bleed hole
