01-03-2013, 01:21 AM
Re: Parting out modded 89 Caravan turbo
My Ride: Various
Spearco Intercooler 1080cfm (new): $400
Griffin Aluminum Radiator (new): $100 ( there has been a little fin damage in storage but will work fine)
Built transmission A413: $500 (Modified valve body, modified governor valves, bypassed accumilator, Alto Red Eagle power pack clutches 6 disc front & 4 disc rear, modified return spring on front clutch pack for firm shift, modified differential with traction aid & solid shaft & brackets & big neon bearing for strength, solid neon pinion, neon transfer nut tension keepers with neon transfer gear cover, all new seals & rings, 581HS converter, neon bands, and case drilled/tapped/plugged for easy external adjustment of line pressure (to adjust governor)-over $2000 Invested
Garrett T3/T04E Turbo (no shaft play)-$150
I will post more parts and prices I just needed to get something up as a pricelist.
