crankshaft pulley and lower timing belt sprocket - Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more!
Parts Wanted Post the turbo dodge parts you are looking for here. TD-specific items only.
post #1 of 26 Old 06-07-2016, 10:51 PM Thread Starter
Garrett Booster
My Ride: 1985 laser xe
Engine: 2,2 Turbo I
wanted a crankshaft pulley and lower timing belt sprocket for a 1985 lebaron gts 2.2 turbo. it has 2 v belt grooves and 1 serpentine
schrenkma is offline
post #2 of 26 Old 06-07-2016, 11:52 PM
Level 4 Supporter
Re: crankshaft pulley and lower timing belt sprocket
I have both for a 2.5 turbo common block..would the work? pm if interested
acannell is offline
post #3 of 26 Old 06-08-2016, 09:12 AM
TryHard Status
turismolover22's Avatar
My Ride: 1986 Daytona Turbo Z
You need an 88 or earlier crank pulley might have one in the box at the shop
turismolover22 is offline
post #4 of 26 Old 06-08-2016, 09:12 AM
Level 3 Supporter
4Daytonas's Avatar
My Ride: 84 Turbo Z, 91 Shelb
Engine: 2.2-2.5
No they are different
4Daytonas is offline
post #5 of 26 Old 06-08-2016, 09:14 AM
Level 3 Supporter
4Daytonas's Avatar
Engine: 2.2-2.5
I'm pretty sure I have the pulleys I'll check. also may have the Crank sprocket for the timing belt.
post #6 of 26 Old 06-08-2016, 09:56 AM
TD Extreme User!
Negative. 88 have 5 bolts crank. He needs a 85-87 4 bolts crank pulley.
tryingbe is offline
post #7 of 26 Old 06-08-2016, 01:46 PM
Hybrid Booster
My Ride: 1992 IROC R/T
Engine: 16V
Images: 10
1985 part book
TIMING BELT, SPROCKETS, COVERS 4 CYLINDER 2.2 L ENGINE, M,Z,P,D,C,V,E,T,H,K,J
1 4105 714 1 COVER, Timing Belt, Upper
2 4343 639 1 COVER, Timing Belt, Lower
3 6500 778 3 SCREW, Timing Belt Cover (M6 x 20 Lgh.)
4 6100 516 2 NUT, Timing Belt Cover
6100 041 1 U-NUT, Timing Belt Cover
5 5203 469 1 PULLEY, Tension
6 6101 277 1 SCREW w/Washer, Tension Pulley Mounting
7 5203 401 1 BELT, Timing
8 6500 831 1 SCREW, Camshaft Sprocket
9 6500 346 1 WASHER, Camshaft Sprocket Screw
10 6500 150 1 KEY, Camshaft Sprocket
11 4201 974 1 SPROCKET, Camshaft (Except EDJ-H/Perf. Eng.)
4201 992 1 M,Z W/(EDJ-H/Perf. Eng.
12 4201 974 1 SPROCKET, Intermediate Shaft (Except EDJ-H/Perf. Eng.)
13 6500 346 1 WASHER, Intermediate Shaft Sprocket Screw
14 6500 831 1 SCREW, Intermediate Shaft Sprocket
15 6500 150 1 KEY, Intermediate Shaft Sprocket
16 5203 575 1 SPROCKET, Crankshaft
17 6500 150 1 KET, Crankshaft Sprocket
18 6502 976 1 SCREW, Crankshaft Sprocket
19 6500 431 1 WASHER, Crankshaft Sprocket Screw
20 5214 636 1 SHIELD, Timing Belt
21 6101 278 1 SCREW w/Washer, Timing Belt Shield Mounting (20mm lgh.)
22 6101 279 1 SCREW w/Washer, Timing Belt Shield Mounting (55mm lgh.)
23 2094 631 1 PLUG, Timing Belt Cover, Upper
24 4227 940 1 PLUG, Timing Belt Cover, Lower
Drive Pulleys
1 5214 065 2 SHIELD, Idler Pulley
2 4273 208 1 BRACKET, Idler Pulley
3 0271 502 1 NUT
4 3830 196 1 PULLEY, Idler
5 6025 677 1 SCREW
6 PULLEY, Drive
4298 125 1 exc. H, w/Air Cond.
4273 163 1 H,K w/Air Cond.
4273 184 1 H,K w/o Air Cond.
7 6500 350 4 BOLT
8 6500 136 3 SCREW w/WASHER
9 4273 181 1 PULLEY, Water Pump
10 4273 096 1 PULLEY, Water Pump
11 6500 665 3 SCREW w/WASHER
12 MD02 5669 1 PULLEY, Camshaft
13 MD00 8835 1 BOLT, Flange (10x25)
14 MD02 0830 1 BOLT, Crankshaft Pulley
15 MD02 0831 1 WASHER
16 MD07 4096 1 PULLEY, Crankshaft
4298125 is the 3 belt pulley 1983-87
marty mopar is offline
post #8 of 26 Old 06-08-2016, 09:17 PM Thread Starter
Garrett Booster
Engine: 2,2 Turbo I
I'm not sure. what year is it? thanks
post #9 of 26 Old 06-08-2016, 09:20 PM Thread Starter
Garrett Booster
Engine: 2,2 Turbo I
Just saw the thread, thanks for the feedback. I would need both the timing sprocket and the pulley. I heard the 5 bolt might work if the sprocket was also replaced. is that correct?
post #10 of 26 Old 06-08-2016, 10:22 PM
TryHard Status
Oh yeah thats right, forgot the 88 pulley was the unicorn square tooth 5 bolt pulley
post #11 of 26 Old 06-09-2016, 10:56 AM
Level 3 Supporter
4Daytonas's Avatar
Engine: 2.2-2.5
I have both-Pmed you
post #12 of 26 Old 06-09-2016, 12:14 PM
My Ride: 87 shelby z
I have one off an 87 Daytona 2.2 turbo.
will ship
603-343-7878
Kenny
knardz is offline
post #13 of 26 Old 06-09-2016, 11:16 PM Thread Starter
Garrett Booster
Engine: 2,2 Turbo I
For some reason i cannot see this thread correctly. any ideas?
post #14 of 26 Old 06-10-2016, 07:54 AM
Level 3 Supporter
4Daytonas's Avatar
Engine: 2.2-2.5
It's typical when people change shit for the (better?). Amazon did it ,My bank did it,and now TurboDodge.com has screwed up the best site ever!
post #15 of 26 Old 06-10-2016, 08:54 AM Thread Starter
Garrett Booster
Engine: 2,2 Turbo I
haha, the price of progress!
Human Verification
