06-04-2012, 08:45 PM
Re: Do-It-Yourself Paint Job questions..
As said above, youtube has a lot of info and prep and clean is your friend! I'm in the process of doing this to my Shelby Lancer right now and just removed the front end tonight. Already have the engine bay scuffed and prep'ed pretty good, but still got another couple hours of scuff pads (3M red) and sander (maybe some block sanding), if not more to go before I'm ready to 2k primer. I'm using simple green and water hose and following up with lacquer thinner while using the scuff pad and its removing all the oil and grease plus paint. Will follow up with a pressure washer later and then some grease and wax remover before a tack rage. Ordered most of my supplies from TCP Global - Quality & Service Since 1974 . Have not started to look at the body yet, but from doing our 1985 Shelby charger, block sanding using 180g up to 2000g until your fingers fall of is the key :) sand down to metal, 2k Primer, block sand, primer/sealer, block sand, base coat, wet block sand, another base coat, wet block sand and clear coat and wet block sand 3000g, buff.. We had lots of mistakes over the years and you learn fast. Seems like best time to paint is at night, but bugs become a big issue in the summer time. We made a paint booth in one of our garage bays, but still had dust issues. wet block sanding helped this a lot. using the proper reducer also helped a lot with runs and flash times.
