Old 06-13-2008, 06:49 PM   #1
Question rear veiw mirror
My Ride: 87 daytona pacifica
Engine: 2.2l
could sombody please measure how far down the "metal button" is glued on on there windshield for a 87 daytona? I cant tell where mine was glued on befor it fell off thanx
turbopac is offline
Old 06-13-2008, 11:51 PM   #2
Re: rear veiw mirror
Hybrid Booster
My Ride: 90Shelby/92 IROC rt
Engine: vnt 2.2l/2.2t3
What kind of glue are you going to use for that, mine came off too.
MNmopar is offline
Old 06-14-2008, 12:59 AM   #3
My Ride: 84 Turbo Z, more
Engine: 2.2-2.5
5inches from the w/s molding to bottom of mirror mount
4Daytonas is offline
Old 06-14-2008, 01:01 AM   #4
Engine: 2.2-2.5
Auto parts stores have the "GLUE" you need.Ask for mirror mount glue.
Old 06-14-2008, 02:41 AM   #5
Turbo-Baron's Avatar
My Ride: 89 lebaron /shadow
Engine: 2.5 turbo
Images: 20
I just eye balled mine it worked out ok lol.
Turbo-Baron is offline
Old 06-14-2008, 03:06 AM   #6
My Ride: 99Mustang
Engine: 3.8 V6
Induct: Nitrous
keep it off, looks cleaner. I did
scorpion1 is offline
Old 06-14-2008, 10:06 AM   #7
If you eyeball it, make sure the sun visors don't interfere with it.
djd's turbo is offline
Old 06-14-2008, 03:26 PM   #8
Thats odd that the old glue did not leave a mark on the windshield.They fall off all the time at work, cars sitting in the lot with the windows up in the heat....
I usually just mark the spot on the outside of the windshield with a crayon and then clean the glue with a razor blade.
The adhesive is "rear veiw mirror adhesive" made by permatex.
A couple of things, be sure all of the old adhesive is cleaned thoroughly from the mirror button, I usually clean it with the wire wheel on the bench grinder.
DO NOT follow the mounting instructions for dry time and hanging the mirror.Follow the instuctions for the cleaner/activater in the small vial and let it dry thouroughly on the windshield and button but then they say 1 small drop of adhesive in the center of the button, use a little more, they say the mirror can be hung in 15 minutes, BS!!!!, Hold the button in place for 1 minute with your finger then use masking tape to hold in place for 12-24 hours or it will fall off again. Try to wait until the windshield is cool and do it in the shade or when the sun goes down.
NAJ is online now
Old 06-14-2008, 04:54 PM   #9
Engine: 2.2l
thanx all ,yeah I just did want it it get hit with the visors thanx
turbopac is offline
Old 06-14-2008, 05:18 PM   #10
My Ride: 88J 94P 03dime
Engine: 2.2 in all of em
heres another couple tips
if you dont have the bracket and end up buying a new one from a parts store, DO NOT use the plastic ones they are selling! they dont fit and WILL break!
autozone oriellys and advance sell the metal brackets in a pack of three- the one for our cars is in that pack.
dont use cheap glue- like NAJ said use the permatex pro glue- its seems to be the best stuff out there at the moment.
i didnt let mine set for 24 hours but i did let it set for 3-4 before putting the mirror on the bracket.
to give the glue an extra bite on the bracket , take the mounting surface and chamfer the edge all the way around. then lightly go over the rest of the mounting surface with the grinder or some rough grit sandpaper. this gives the glue a nice rough surface to grab onto.
if you're using a new bracket you will definately have to chamfer the edge- you'll see a small lip on the edge if you look at it closely. you have to get rid of that lil edge or the bracket will not make proper contact with the glass.
also the new brackets have oil on em to prevent rusting in the package- spray it off a couple times with carb or brake cleaner before using the primer.
dont over use the glue- all it takes is one fat drop like the instructions say, more will not hold it any better and just makes a nasty lookin mess on your windshield.
oh as far as leaving the rearview off, most states require you to have one if you can see out the back window, if a cop wanted to be a dick he could give you a ticket for it.
crusty shadow is offline
Myspace Layouts | Read this exciting weblog | Mobile Phones | Gas Suppliers | New Jordans
Page generated in 0.38379 seconds with 13 queries
