07-05-2008, 04:45 PM
Re: Interior Removal
Well, the only experiance I have with a TD is my 90 and the "A" pillar trim is retained with push pins, if this is a 2 door the rear is all part of the rear quarter trim panel, which is another story all together. If this is the case, removal of the rear seats first will make it easier.
Removing panels that have clips into the body is always a pain, I go thru this all the time at work with newer Jeeps, they are so concerned with rattles/vibration that the panels are difficult to remove.
You need to locate the points were the clips are located and get behind the panel with a large tipped screwdriver or clip removal tool and twist right at the point where the clip is located to disengage it from the body.
If your 89 is similar to a 90 AJ I will post Chryslers removal procedure for you, it may show clip/screw location and may aid in removal.
