Old 07-19-2008, 04:25 PM   #1
short shifter diy
My Ride: 89 Daytona Shelby
Engine: 2.2l Turbo II
ok so i searched around the site looking for a thread on making a short shifter out of the stock 89 a555 shifter and was wondering how people are doing it, i have seen pictures in thread about other things that look like the stock shifter but are shorter, i could do it but was wondering how you guys are doing it and still keeping the reverse lockout still working
mondo1982 is offline
Old 07-19-2008, 04:26 PM   #2
Re: short shifter diy
My Ride: 86 Laser XT
Engine: 2.2 turbo
Images: 2
hellafast.com Photo Gallery :: Short Shifter
Old 07-19-2008, 04:33 PM   #3
Junkyard Booster
My Ride: 86 GLHT
Engine: 2.2 turbo
that won't help that much on that site. just makes the shaft shorter. ask lotsofshelbys he does them all day long.
roachjuice is offline
Old 07-22-2008, 01:56 AM   #4
My Ride: 86 SC, 94 Duster
Engine: 2.2 TI, 3.0L
Ain't it lotashelbys? or lotsashelbys? I think it's the 1st one. It's not lotsofshelbys, though. Just do it like the sticky says & look at it to figure out what to do differently for the lockout. It's not too hard.
Sittn86 is offline
Old 07-22-2008, 04:54 PM   #5
SHELBY 16V !!!
lotashelbys's Avatar
My Ride: Lots of TIII cars:-)
Engine: 16V TIII
Feedback: (17)
Images: 1
It me
Just look at the "short throw shifter" sticky in the transmission section,I have pics of how I do it on there and if you cant figure it out I cant make you one
~Jackson~
TIII GURU
91 Spirit R/T
91 Spirit R/T(GFs hotrod)
lotashelbys is offline
Old 07-22-2008, 05:39 PM   #6
ok thanks guys thought it would be in interior since that is where it is on the car, oh well lol
Old 07-23-2008, 03:03 AM   #7
My Ride: '88 Shelby Z TII
My buddy and myself built one...it isn't hard really. The hardest part was the reverse lock out, but that's because my buddy that was helping me was intent on doing it his way. It worked, just took a few trial and errors before it was right!(and I thank him VERY much for his hard work and efforts!!) We used Jackson's images quite a bit for refference.
I WILL say that raising the base 3/4" is about all the higher you really can or would want to go! Anything mroe than that and the shifter base *might* hit the center console, it WILL be a royal pain to get the shift lock-out retainer pin in, and the throw will be right around "too-short"! LOL
Reaper1 is offline
Old 07-23-2008, 07:33 PM   #8
NORCAL
86trbolancer's Avatar
My Ride: 86DodgeLancerPacific
Engine: T2'd 2.2L
Feedback: (6)
Images: 32
i'd love to do this in my lancer if i could figure how to put the a555 shifter in place of the a525...
If you could help...i just posted in the HELP forum
'86 Lan. Pac. 2.2LT2d CB w/ FWDp Eagel Rods, .040 venolias, ARP studs everywhere, ported exhaust mani, g-valved, egt & boost gauge pillar pod, custom cal, TU 4-puck yellow pp, a555 w/ quafie lsd, alum. flywheel, Full 3in mandrel bent exhaust w/ TU 3in SV & OBD2 h/f cat, Magnaflow straight through muffler, Turbonetics t3/t4 .63 ar stage 2 wheel w/ custom weld job to clear head, cummins fmic, KONI adj. coilovers, adj. rear koni shocks, SLH ''11inch. vented rear rotor conversion
86trbolancer is offline
Old 07-23-2008, 07:45 PM   #9
Engine: 2.2 turbo
Images: 2
I wanna say it will bolt right in no prob IIRC!
Old 07-23-2008, 07:48 PM   #10
NORCAL
Engine: T2'd 2.2L
Feedback: (6)
Images: 32
check it out...
I'ma post some pics over in the other posting i made....
it sux
Old 07-23-2008, 08:18 PM   #11
My Ride: TIII R/T
Engine: 2.2L TURBO III
Feedback: (10)
that 525 and the 555 should use the same everything 86, to my knowledge the lancer never came rod shifted so that cant be the problem
xtrempickup is online now
Old 07-24-2008, 12:32 AM   #12
No, but they had a REALLY crappy crossover set-up. It is similar in design to the DSM's. I don't remember if you can bolt in a later 4-plane shifter and make it work or not. You *may* have to swap the cross over cable as well to make it work, but I'm not 100% on that.
Reaper1 is offline
Old 07-24-2008, 11:00 AM   #13
NORCAL
Engine: T2'd 2.2L
Feedback: (6)
Images: 32
What is the "cross over cable"???
I've been trying the use one cable from my a525 and one from the a555 since 1 i got with it didn't have enough throw. Not sure why throw would be different...I think the guy i bought it from on here kinda stiffed me a lil and sent me wrong cables.
I can get the cables to mount up to my old shifter but the throw was never good enough to even give me confidence to go and try to drive it...I've lubed the cables so they're not sticking inside(slide'n like butter).
Hummm...I have the tranny out now maybe i should do an out of car mock up to make sure the cables i have are swinging the shift fork the right distance.
Thanks for your help guys
Take all i can get..
Whos got the bad ass lancers on here?...i know there is t3 guru's(jackson)
Old 07-25-2008, 01:17 AM   #14
What I call the "cross over" is the cable that changes the shift plane from 1-2 to 2-3 to 5 to R. Basically it's the cable that controls the side-to-side action(or if you are messing on teht tranny part of the thing it would be from front to back on the shift housing).
Reaper1 is offline
Debt Help | Honda CBR600RR | Bad Credit Mortgages | Mortgage | Loans
Page generated in 0.40802 seconds with 13 queries
