09-28-2008, 06:50 PM
#20
Re: Boost Guage
My Ride: 1986 GLH Turbo
Here's my installation. I wanted it on the right side of the radio as it is partially blocked by the steering wheel if I mount it on the left side. I have it mounted, but not hooked up yet. I had to shim it with 5 washers on each side to make it fit flush with the bezel - I did not glue it to the bezel, but mounted it to the dash. It's a tight fit as the air ducting is right behind it, but there is clearance enough I think. As I am new to this, where do I plug into the vacuum lines to hook it up?
