08-18-2008, 02:03 AM
Re: Omni HVAC Problems
My Ride: 93 Notchback
The last time I took the dash apart, I had vacuum at the little "tree" that holds the lines at the back of the HVAC unit. I then took a spare piece of that tubing and manually hooked up all of the other controls one at a time to the vacuum line port in the tree, and could make all of them work. I am "pretty sure" that I don't have any vacuum leaks from the motor to the HVAC, and from the HVAC to the vacuum canisters that move the doors that direct air, I also don't have any easily detectable leaks, as everything will work if you make a direct connection between the two holes in the tree. Basically I "think" that the problem is in the HVAC controls, and wondered if there is an easy fix, and if not, what controls will work in an omni?
Oh, and yeah, I don't think the cable is working for the temp slide. I will probably have to get a new one, are there any cheap/easy ways to do this? or do I have to stand on my head?
Chris
