08-20-2008, 04:27 AM
Re: '94 shadow door trim
My Ride: 86 SC, 94 Duster
Engine: 2.2 TI, 3.0L
Grease the window channel behind the glass. The window has plastic/metal "skis" (for lack of a better word) that ride in the channel. Once there's no grease left, the window will pop, bind, etc. The crank will even skip teeth inside the regulator. The easiest & cheapest way I've found is to put grease in the corner of a small ziploc bag & cut a tiny part of the corner off. Put the corner of the bag in the channel & squeeze gently. Just don't use too much or get it on the glass. If the car has an automatic passenger seatbelt, you can use the pastry frosting grease bag for that, too.
Even if this isn't the cause of the problem, it's still good maintenance for any P-body.
Edit: Don't use a cheap bag. The seam would probably split, causing a rather annoying mess.
