Old 11-13-2003, 12:15 PM   #1
88 lancer infinity wire diagram
I have a 88 lancer that came with the infinity system but only the right rear speaker seems to work and that doesn't even seem to be working right. all the speakers are said to be new if i can't get it figured out i might just go and rewire the car for regular speakers.
Thanks
glhs659 is offline
Old 11-14-2003, 06:24 PM   #2
i have an 88 service manual for a 88 daytona.i think the wiring diagram for the radios should be the same do you have access to a fax?
silvershelby387 is offline
Old 11-14-2003, 06:40 PM   #3
The BoostBaron
Regular speakers...
i'd recommend playing around with your existing stuff to try and figure out where the problem is, before you gotta go buy any new stuff.
You've probably already looked, but definately check the balance/fader.
If not, try out the speakers in someone elses car, or quickly brush the speaker terminals across a AA battery and listen for a sound (if they pop in and out, then they should work)
if the speakers are good, then the problem is either in the wiring or the head unit. Run a continuity tester across the speaker lines to make sure they're wired up properly. If the wires are all good, then its got to be the head.
Old 11-14-2003, 06:56 PM   #4
The BoostBaron
sorry, ignore me, i forgot that the infiniti system is way different than your average setup.
me--> <--me
Old 11-15-2003, 10:08 AM   #5
I'll see if I can get access to a fax. Isn't there anyway you could email it?
Thanks
glhs659 is offline
Old 11-18-2003, 10:36 AM   #6
Fixed
I got my infinity setup working, it was just a ground problem thanks for the help.
glhs659 is offline
Old 11-22-2003, 10:49 PM   #7
silvershelby387 could you email me that wiring diagram? my email is ieatspam4lunch@yahoo.com.
Thanks
1985ShlbyChrger is offline
Old 11-23-2003, 04:52 PM   #8
i dont have a way to e-mail it to you it is in a service manual.i can make copies and mail them or fax them to you.pm me with a fax # or an address.
Loans | Loans | Web Hosting | Final Fantasy Wallpapers | Credit Card Consolidation
Page generated in 0.41151 seconds with 13 queries
