Old 12-16-2003, 09:34 PM   #1
Rewiring Fog Lamps
My Ride: '90 Shadow ES VNT
Long ago I saw something about rewiring fog lamps so they can be turned on anytime, not just when the headlamps are on low.
I think it was something simple like running a new power source to the switch but I can't remember or find the article.
Anyone ever heard about this or done it?
Thanks, Mike
'90 Shadow ES T28 VNT
Mikestr is offline
Old 12-16-2003, 10:06 PM   #2
shouldnt be to hard a relay a switch a digital multi meter or test lamp. and some spare time to trace wires an inline fuse and a switch. hell theres even aftermarket kits you can add on to make em remote operated (great if u cant find your car in the parking lot) loot at my cardomain site itl show you my switches.
ravenc is offline
Old 12-17-2003, 06:31 PM   #3
T2Ryoku
So you won't them to come on when you turn your parking lights on? Try to find a manual that shows what wire is the parking lights power source and t-tap it in. :big grin:
Old 12-18-2003, 05:00 PM   #4
My Ride: 1991 Daytona Shelby
Engine: SOHC 2.5L
I can see what he wants to do. He wants to be able to turn on the fogs and just the fogs but without the low beams coming on, and doing this by using the existing fog light switch. I want to do the same thing since on g-bodies the headlamps pop-up but don't come on when you want just the fogs, really silly. Plus I want to put them down when racing at night on the track since I'm sure it causes some drag but I need light!
91DSX is offline
Old 12-23-2003, 12:23 AM   #5
hope this helps some ...the 88 manual for daytonas you would need to cut the violet wire at the connector to the fog lamp switch and run a wire to the black yellow wire at the headlamp switch which should show power with the parking lights on ..
which car are you trying to do this on ??
the 90 daytona would be different and i can go look at my 90 manual tomorrow and see what would need to be done for a 90 daytona
rick
quickcar is offline
Old 12-23-2003, 12:30 AM   #6
you dont want to just tap a wire into the parking light source and run it to the fog light wireing without cutting the wire to the foglamp switch first and run the parking light source to the fog lamp switch only if you dont cut the wire the low beams would come on every time you turn your parking lights on ..
i wasnt sure if you meant to cut the wire or not so i fiqured i would clarify
"thumbs up
quickcar is offline
Old 12-26-2003, 09:16 PM   #7
For clarification I want to be able to turn on the fog lamps no matter where the headlamp switch is, on, off, high, low, whatever.
By design the fog lamps only work now when the headlamps are on low beam.
Car is ’90 Shadow ES VNT.
Mikestr is offline
Old 12-27-2003, 12:40 AM   #8
ok i understand now youll want to take the 16 ga violet wire at your fog lamp switch and cut it and wire the end that goes to the switch to a constant source you can tap it into the pink wire at the foglamp switch ...
now also do you want them to be able to be turned on regardless of the igntion switch position????
doing what i described above will allow them to be turned on regardless of the headlamp postion but the igntion switch will still have to be in the run position ...
rick
quickcar is offline
Old 12-27-2003, 01:09 AM   #9
wired headlights for remote operated
heheh let me look at for 5 min all have em working right ignition no ignition and on remote switch if u want i got my headlights on a remote operated switch its pretty easy find. should be able to use a fuse tap then run that to the switch. or u might hafta wire em in to the lights and use a relay. and tap the switch. should be easy tho jus figure out the order swich headlight switch lights
ravenc is offline
Old 01-08-2004, 01:57 PM   #10
[quote]Originally posted by quickcar
Could you please look up the 1990 Daytona info.
One summer i unplugged the headlights and the just used the fog lamps, but would also like to re-wire them myself. thnx.
Fast4Ward is offline
Mortgage Calculator | Child Trust Funds | Remortgaging | Creative Electronics | Unique MySpace Layouts
Page generated in 0.36349 seconds with 13 queries
